Is there a new FAT component for the new Eblock?
E-blocks2 SD Card Board BL0154
http://www.matrixtsl.com/webshop/e-bloc ... board.html
E-blocks2 SD Card Board BL0154 new FAT?
- Has thanked: 182 times
- Been thanked: 179 times
Re: E-blocks2 SD Card Board BL0154 new FAT?
Hello Stefan,
The existing FAT component will work with the new micro SD card E-block 2 board BL0154.
The E-block also supports the API mode but currently there is a licensing headache to get right here so for the moment we are not actively working on this. Looking at the ST ARM source code they seem to support the API mode via libraries but the source is unavailable and to use it I believe you need to pay a license fee.
" I believe you need to pay a license fee"
For me and my company it's not a problem to pay it.
I suspect some another user would pay a little more.
I hope Matrix will not stop improving the FAT.
Electrocardiography,Sleep Laboratory, Neurology,Motion analysis and generally in research
are so much data for recording, mostly with 8channels or even more in 16 or 24bit resolution. This data is usually recorded over several hours. Flowcode is very well suited for that. Flowcode is stable and very reliable.
Even medical students for the masterwork or researchers personnel can set parameters in Flowcode. And there is a lot of harware avaible for Flowcode.
A small weak point is the speed to save and/or transfer the data. Especially if the data rate is around 1 megabits / sec. ( I mean Megabit not even Megabyte...)
It's not that we have to go to the limit of a SD-card, but a little faster.
And the Eblock2 SD Card BLO154 is ready for it.....
