Morning
Looking at the Locktronics stuff is there a basic electrical package to be able to teach "relay logic systems " to our apprentices as this topic don't seam to be taught anymore in collages.
looking for:
A supply
Relay with coil N/O, N/C contacts or change over contact
Push Buttons N/O, N/C
Switch(s)
Volt Meter
Ammeter
Lamp or LED
Before i get a raft of suggestions to move into the 21st century and use a PLC like i did from one of our apprentices collage lecturers, 95% of our customers do not allow PLC's in there control systems and this is written into the spec's.
Locktronics Equipment
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Locktronics Equipment
Hi Steve,
We don't have a relay logic training package, but do have a range of switches and relays..
http://www.matrixtsl.com/locktronics/co ... x.php?L=17
http://www.matrixtsl.com/locktronics/co ... x.php?L=22
I'll pass your suggestion on and see if there are any other options.
Thanks,
Leigh
Thanks,
Leigh
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Hi Steve,
To supplement Leigh's answer, here are the range of bulbs and LEDs:
http://www.matrixtsl.com/locktronics/co ... x.php?L=23
And here are some meters, although for accurate readings we would recommend hand-held multimeters:
http://www.matrixtsl.com/locktronics/co ... x.php?L=11
Looking at your list, we do not have N/C relays and switches, but we do have blank carriers which allow you to make your own:
http://www.matrixtsl.com/locktronics/co ... ex.php?L=2
Hope this helps.
Steve.
Hope this helps.
Steve.
- Has thanked: 460 times
- Been thanked: 523 times
Hi Leigh / Steve
I will show my Engineering Manager and see what happens fingers crossed
