Numerous errors when compiling to HEX code
Posted: Sat Mar 24, 2018 9:54 am
by keejay
Hi, I have just stared using FC7. I wrote a small test flowcode, but when I try and compile, I get a heap of errors. I'm sure its just a setup issue. Is there a topic that discusses the setup of FC7 and compiler setup? I've attached the small FC, but not sure how to attach the error report as I wont let me copy it.
Re: Numerous errors when compiling to HEX code
Posted: Mon Mar 26, 2018 12:30 pm
by keejay
Anyone from MATRIX???? Please assist....
Posted: Mon Mar 26, 2018 12:55 pm
by LeighM
There is nothing wrong with your project file.
Where are you saving it on your PC?
Could the problems be due to admin rights on the directory?
Why can't you read/copy "Test_FC7.msg.txt"?
Posted: Mon Mar 26, 2018 4:33 pm
by keejay
My apologies,
I've attached the .msg file. If I remove the LCD component then it compiles?
Thanks.
Posted: Tue Mar 27, 2018 8:29 am
by LeighM
Could you try downloading and installing the patch update zip from here ...
http://www.flowcode.co.uk/mmforums/viewt ... 63&t=19743
Posted: Tue Mar 27, 2018 12:13 pm
by keejay
Thanks very much, that seems to have sorted the problem!!
