DAC Output
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
CSM2711
Has thanked: 1 time
Been thanked: 9 times
DAC Output
Post by CSM2711 »
is there a possibility to import the DAC Output component from FC V7 to V6 ?
Re: DAC Output
Sorry this is not possible, v7 components cannot work with v6 due to lack of functionality and CAL code.
You can use C code icons in your v6 project if you want to drive the DAC registers for your device. The DACs are quite straightforward so this shouldn't be too hard to do.
