Page 1 of 2
The MIAC dsPIC menu not work with EEPROM
Posted: Sat Jun 09, 2018 1:16 pm
by Monie Jacobsen
Hello Everbardy
Is there anyone here that could help to get the MIAC dsPIC menu to work?
I get an error by uploading the MIAC dsPic codes.
If I remove EEPROM, I can upload the codes to MIAC. And the program works.
Is there anyone here that will help solve the problem?
Attach MIAC code:
MIAC dsPIC Menu Test.fcfx
(31.37 KiB) Downloaded 471 times
Hope that someone will help solve the problem.
Compile message with error message:
Target folder: C:\Users\Bruger\Desktop\TILFOR~1
Source name:   C:\Users\Bruger\Desktop\Til Forum\MIAC dsPIC Menu Test.fcfx
Title:
Description:
Device:        PIC16.33E.MIAC (dsPIC) System
Generated by:  Flowcode v7.3.0.5
Date:          Saturday, June 09, 2018 12:52:33
Users:         1
Registered to: monie jacobsen
Licence key:   YUWNEC
http://www.flowcode.co.uk
Launching the compiler...
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat  "MIAC dsPIC Menu Test" "C:\Users\Bruger\Desktop\TILFOR~1\" "33EP256MU806"
Launching compiler...
C:\Users\Bruger\Desktop\TILFOR~1>xc16-gcc -c -mcpu="33EP256MU806" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "MIAC dsPIC Menu Test".c -o "MIAC dsPIC Menu Test".o
Options have been disabled due to restricted license
Visit http://www.microchip.com/ to purchase a new key.
MIAC dsPIC Menu Test.c:395:13: error: expected declaration specifiers or '...' before numeric constant
MIAC dsPIC Menu Test.c: In function '_EEDATA':
MIAC dsPIC Menu Test.c:395:16: error: expected declaration specifiers before 'NonVolatileData'
MIAC dsPIC Menu Test.c:395:78: error: expected declaration specifiers before ';' token
In file included from C:\Program Files (x86)\Flowcode 7\CAL\includes.c:41:0,
                 from MIAC dsPIC Menu Test.c:405:
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:48:17: error: storage class specified for parameter 'WG_CursorX'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:49:17: error: storage class specified for parameter 'WG_CursorY'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:51:13: error: storage class specified for parameter 'WG_Write'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:52:17: error: storage class specified for parameter 'WG_Read'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:53:13: error: storage class specified for parameter 'WG_Command'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:54:17: error: storage class specified for parameter 'WG_Status'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:55:13: error: storage class specified for parameter 'WG_WriteWordAt'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:56:18: error: storage class specified for parameter 'WG_ReadWordAt'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:60:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:104:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:152:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:167:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:182:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:199:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:220:17: error: storage class specified for parameter 'MIAC_SPI0_cs'
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:223:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:268:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:296:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:305:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:322:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:327:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:361:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:377:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:386:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:392:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:444:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:466:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:514:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:521:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:573:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:578:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:599:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:610:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:621:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:632:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:643:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
In file included from C:\Program Files (x86)\Flowcode 7\CAL\includes.c:238:0,
C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:51:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:68:4: error: #error "Chip does not have EEPROM memory"
C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:73:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:129:4: error: #error "Chip does not have EEPROM memory"
MIAC dsPIC Menu Test.c:426:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:436:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:451:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:460:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:474:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:483:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:497:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:506:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:520:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:529:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:543:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:552:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:566:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:575:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:589:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:599:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:614:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:624:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:639:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:649:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:664:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:674:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:689:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:699:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:714:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:724:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:739:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:749:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:764:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:774:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:789:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:799:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:817:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:858:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:943:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1050:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1084:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1105:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1167:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1190:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1255:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1298:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1345:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1404:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1425:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1440:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1632:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
MIAC dsPIC Menu Test.c:1924:1: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:40:6: error: declaration for parameter 'FC_CAL_EE_Write' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_EEPROM.c:39:11: error: declaration for parameter 'FC_CAL_EE_Read' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:220:17: error: declaration for parameter 'MIAC_SPI0_cs' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:56:18: error: declaration for parameter 'WG_ReadWordAt' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:55:13: error: declaration for parameter 'WG_WriteWordAt' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:54:17: error: declaration for parameter 'WG_Status' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:53:13: error: declaration for parameter 'WG_Command' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:52:17: error: declaration for parameter 'WG_Read' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:51:13: error: declaration for parameter 'WG_Write' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:49:17: error: declaration for parameter 'WG_CursorY' but no such parameter
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:48:17: error: declaration for parameter 'WG_CursorX' but no such parameter
MIAC dsPIC Menu Test.c:400:6: error: declaration for parameter 'FCD_06651_eeprom1__Write' but no such parameter
MIAC dsPIC Menu Test.c:399:11: error: declaration for parameter 'FCD_06651_eeprom1__Read' but no such parameter
MIAC dsPIC Menu Test.c:2032:1: error: expected '{' at end of input
Error returned from [xc16-gcc.exe]
Completed compilation, return = 1
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat reported error code 1
FINISHED
Re: The MIAC dsPIC menu not work with EEPROM
Posted: Sat Jun 09, 2018 1:46 pm
by kersing
The controller in the dspic miac does not contain an eeprom so you can not use the eeprom component.
These is a component that simulates an eeprom on the dspic hardware, search the forum to find it.
Posted: Sat Jun 09, 2018 3:57 pm
by Monie Jacobsen
Hi kersing
Thank you for the information and descriptions of missing eeprom in miac dsPIC.
Hi Leigh,
Hope to be able to get another solution to the missing eeprom?
Posted: Sat Jun 09, 2018 4:36 pm
by kersing
Have you checked my proposed solution?
Posted: Sat Jun 09, 2018 6:36 pm
by Monie Jacobsen
Hi kersing
No, I have not understood!
Do not understand how it can be done. do you?
Has not found anything useful on the forum...
Posted: Sun Jun 10, 2018 1:00 am
by kersing
Check viewtopic.php?f=58&t=15932. That component simulates an eeprom using flash.
Posted: Sun Jun 10, 2018 11:50 am
by Monie Jacobsen
Hi kersing
Thank you very much for your help.
MIAC dsPIC Menu with (eeprom) Flash works, now also in the real world ;-)
It was almost too easy.
I will use Flash as memory for MIAC dsPIC in the future...
Attached codes:
MIAC dsPIC Menu Flash.fcfx
(34.1 KiB) Downloaded 506 times
Posted: Mon Jun 11, 2018 8:41 am
by LeighM
Just for further information, the dsPIC MIAC does have serial EEPROM on-board.
This can be used with the Serial EEPROM component ...
Posted: Mon Jun 11, 2018 9:53 am
by Monie Jacobsen
Hi Leigh,
Did not know anything about it the dsPIC MIAC does have serial EEPROM on-board.
Is this unit an inoperable component Serial EEPROM component.
Sorry for the question!
Will of course test your proposal;-)
Posted: Tue Jun 12, 2018 6:07 am
by Monie Jacobsen
Hello Everbardy
I want to exit Menu with GetKey = 6 ???
Desires the following procedure:
1: Set Time
2: And then exit Menu with GetKey = 6
3: Absolutely out of menu
And the action goes on in Macro SetValue
Can not get out of Menu.
Can you see where I'm making a mistake?
Would very much like your help, can not get along with the codes.
Has attached the codes:
MIAC dsPIC Menu Flash-003.fcfx
(97.23 KiB) Downloaded 448 times
Posted: Wed Jun 13, 2018 1:58 pm
by Monie Jacobsen
Hello Everbardy
Regarding the above problem, I really want a help.
Have tried many times, but without luck!
Hope for help?
Posted: Wed Jun 13, 2018 5:08 pm
Hi Monie,
I've added a bit of a hacky way of doing it using gotos to jump out of your macros. Seems to largely work but maybe some more cases need adding.
(99.17 KiB) Downloaded 495 times
Posted: Wed Jun 13, 2018 5:10 pm
This topic may also help, I create a heating controller using the MIAC with things like time setting and the ability to add and edit recurring events.
viewtopic.php?f=36&t=7735&p=42694#p21244
Posted: Thu Jun 14, 2018 9:40 am
by Monie Jacobsen
Hi Benj
Thank you for your help.
I've also added more gotos to jump out of your macros.
This worked;-)
I was stuck in the codes...
It is also intranspected to see your floor heating system.
Posted: Thu Jun 14, 2018 3:36 pm
by Monie Jacobsen
Hello Everbardy
Would you be helpful and tell me what goes wrong?
I can simulate but by compiling to Miac dsPIC result in ERROR see below.
Icon Lists.JPG (18.23 KiB) Viewed 22656 times
Error results:
Source name:   C:\Users\Bruger\Desktop\Til Forum\MIAC dsPIC Menu Flash-007.fcfx
Title:
Description:
Date:          Thursday, June 14, 2018 15:19:46
Users:         1
Licence key:   YUWNEC
C:\Program Files (x86)\Flowcode 7\compilers\pic16\batchfiles\pic16_C30_comp.bat  "MIAC dsPIC Menu Flash-007" "C:\Users\Bruger\Desktop\TILFOR~1\" "33EP256MU806"
C:\Users\Bruger\Desktop\TILFOR~1>xc16-gcc -c -mcpu="33EP256MU806" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\..\support\h" -I"C:\PROGRA~2\FLOWCO~1\COMPIL~1\pic16\BATCHF~1\" -std=gnu99 "MIAC dsPIC Menu Flash-007".c -o "MIAC dsPIC Menu Flash-007".o
MIAC dsPIC Menu Flash-007.c: In function 'FCD_0f151_flashio1__ClearPage':
MIAC dsPIC Menu Flash-007.c:525:20: warning: cast from pointer to integer of different size
MIAC dsPIC Menu Flash-007.c: In function 'FCD_0f151_flashio1__ReadCell':
MIAC dsPIC Menu Flash-007.c:588:20: warning: cast from pointer to integer of different size
MIAC dsPIC Menu Flash-007.c: In function 'FCD_0f151_flashio1__WriteCell':
MIAC dsPIC Menu Flash-007.c:635:20: warning: cast from pointer to integer of different size
MIAC dsPIC Menu Flash-007.c: In function 'FCM_Display_On_OFF':
MIAC dsPIC Menu Flash-007.c:2779:3: warning: passing argument 1 of 'MIAC_PrintString' discards qualifiers from pointer target type
C:\Program Files (x86)\Flowcode 7\CAL\/MIAC\MIAC_CAL_API.c:385:6: note: expected 'MX_CHAR *' but argument is of type 'volatile MX_CHAR *'
MIAC dsPIC Menu Flash-007.c:2801:3: warning: passing argument 1 of 'MIAC_PrintString' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:2828:3: warning: passing argument 1 of 'MIAC_PrintString' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:2850:3: warning: passing argument 1 of 'MIAC_PrintString' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c: In function 'FCM_DayOfTheWeek':
MIAC dsPIC Menu Flash-007.c:4765:4: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:899:13: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
MIAC dsPIC Menu Flash-007.c:4774:4: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:4783:4: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:4792:4: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:4801:4: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:4810:4: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:4819:4: warning: passing argument 3 of 'FCI_SCOPY' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c: In function 'FCM_SolarPosition':
MIAC dsPIC Menu Flash-007.c:4840:13: error: 'MONTH_DAYS' undeclared (first use in this function)
MIAC dsPIC Menu Flash-007.c:4840:13: note: each undeclared identifier is reported only once for each function it appears in
MIAC dsPIC Menu Flash-007.c:5359:2: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards qualifiers from pointer target type
C:\Program Files (x86)\Flowcode 7\CAL\/PIC16BIT\PIC16BIT_CAL_String.c:557:18: note: expected 'MX_STRING' but argument is of type 'volatile MX_CHAR *'
MIAC dsPIC Menu Flash-007.c:5360:2: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:5368:2: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards qualifiers from pointer target type
MIAC dsPIC Menu Flash-007.c:5369:2: warning: passing argument 3 of 'FCI_FLOAT_TO_STRING' discards qualifiers from pointer target type
FINISHED
Vedhæftet:
(149.85 KiB) Downloaded 355 times
Posted: Thu Jun 14, 2018 3:55 pm
by LeighM
The only error I get is this one, due to some C code in SolarPosition
MIAC dsPIC Menu Flash-007.c:4842:13: error: 'MONTH_DAYS' undeclared (first use in this function)
Posted: Fri Jun 15, 2018 8:25 am
by Monie Jacobsen
Hi LeighM
Try to see this version it works!
Just editing another simple version:
I do not know what goes wrong?
Is it the Flash device that is causing problems?
The following works....!
Se attach file:
MIAC dsPIC Menu Flash-0014 OK.fcfx
(139.68 KiB) Downloaded 436 times
Posted: Fri Jun 15, 2018 9:58 am
by LeighM
Hi Monie,
In the 007 version there are warnings that you can ignore.
But you have an error due to this C code in SolarPosition ...
FCV_DAYS = MONTH_DAYS[FCV_MONTH-1];
So you need to either create a MonthDays array as a Flowcode global variable, and then initialise and read the values in calculation icons,
or create a C code initialised array in the "Supplementary Code" (see Build->Project Options)
Posted: Fri Jun 15, 2018 10:44 am
by Monie Jacobsen
Hi LeighM
Sorry Legih I Can not Find Project Options ;-)
My edition is in Danish ...
Do you want to give a Screen dump?
Posted: Fri Jun 15, 2018 11:36 am
by LeighM
Posted: Fri Jun 15, 2018 12:36 pm
by Monie Jacobsen
Hi LeighM
Thank you very much for your proposal.
I will try the proposal and come with a report ;-)
Good'Weekend
Posted: Fri Jun 15, 2018 1:21 pm
by Monie Jacobsen
Hi LeighM
The code below works!
Report!
Suplerende Code.JPG (33.94 KiB) Viewed 22615 times
Thank you very much for the proposal
Posted: Mon Jun 18, 2018 8:12 am
by Monie Jacobsen
Hi LeighM
Working to get attached codes to work with MAC sdPIC, but unsuccessfully.
Would you like to get MIAC sdPIC with the attached coder to work?
Have tried a lot;-)
Se attached flow code works fine via Flowcode with Arduino Mega 2560 R3
Attach file:
Noedstop-002.fcfx
(12.85 KiB) Downloaded 456 times
Posted: Mon Jun 18, 2018 1:40 pm
by Monie Jacobsen
Hello Hello everyone
Is there anyone who has a solution to the above posts?
Have tried a lot of codes, but without luck.
Posted: Tue Jun 19, 2018 8:25 am
by Monie Jacobsen
Hello everyone
When simulated in the Flowcode program, the codes work.
I am working to get MAC sdPIC with the attached codes to work in the real world?
Works to get attached codes to work with MAC sPICE Interrup reset function, but without success.
Have tried a lot ;-)
Would you like to help make the codes work?
Attach file:
MIAC dsPIC Interrup Induktiv Stop.fcfx
(76.08 KiB) Downloaded 382 times
