Problem PIC16EP512GU810 con V8
Posted: Thu Jun 14, 2018 10:17 am
by MOCUELSL
Good morning Benj, when updating to the V8 version of the flowcode, I compile the program that I enclose with the pic16Ep512Gu810 and it gives me error 1; with the previous version of flowcode I did not give any error; You can tell me what is due. Thank you.
Re: Problem PIC16EP512GU810 con V8
Posted: Thu Jun 14, 2018 10:48 am
Please can you check the pin connections for the SPI Master component. This component has been upgraded and so the pin connections from v7 to v8 may be lost.
Everything else looks like it should be ok to me.
Posted: Thu Jun 14, 2018 12:36 pm
by MOCUELSL
I have verified what he has told me and I have effectively changed the pins and it is already working. Thank you very much for your help.
