Hi Matrix Team,
I would like say thanks to you guys for added MCP23017 & MCP23S17 modules in Flowcode8. I have tried with both I2C and SPI (MCP23017 & MCP23S17) demo boards, both are not working. MCU is ATMEGA128A. I have attached my code here. I didn't see any error/Warning while compile. please advice.
Note: I just leave it "INTA,INTB" pins as open.
Karthick.
IO Extender with MCP23017 & MCP23S17 issues [SOLVED]
- Has thanked: 4 times
- Been thanked: 9 times
- MCP23017.fcfx
- (8.52 KiB) Downloaded 283 times
- MCP23S17.fcfx
- (8.69 KiB) Downloaded 303 times
Re: IO Extender with MCP23017 & MCP23S17 issues
Hello Karthick,
Many thanks for letting us know.
I've just looked at the component again and I had accidentally put the register addresses in decimal instead of hex. All seems to be working fine now. You can get the latest fixes now by using the Help -> check for updates menu.
Dear Ben,
Thanks. Even now I can control only PA0 and PB0 ports in 23017 . Other ports are still not working. Please see the logic analyzer screen shot. I switch each port ever 10ms. Even I have tried individually by port by port,but no output. Please advice.
Also I have tested the SPI 23S17 component and the result is same phenomenon as I2C ? Also I didn't see the external slave address option in component property window for MCP23S17. Please help to check.Thanks
- MCP23S17 all port.fcfx
- (10.06 KiB) Downloaded 301 times
- (106.67 KiB) Downloaded 1343 times
- MCP23017 all port.fcfx
- (9.78 KiB) Downloaded 303 times
Aha, many thanks for letting us know. I've spotted an additional bug in the WritePortPin macro when using a pin greater than pin0, I was testing previously using the WritePort macro which is working correctly.
The updated components should now be available and hopefully should all be fixed now.
Let us know how you're getting on.
I've now added this and added a 9th option for don't use if you don't wish the addressing to be switched on.Also I didn't see the external slave address option in component property window for MCP23S17. Please help to check.
HI Ben,
Thanks . All the ports are working now other than PB7. I checked with 2 demo MCP23S17 PCBA's. I just tested only SPI. I will test I2C tomorrow.
- (10.06 KiB) Downloaded 286 times
- (44.58 KiB) Downloaded 1328 times
Many thanks for letting me know.
Port B pin 7 is working well for me with the SPI version (port write and pin write) so maybe check your connections are ok? Strange for two boards to have the same problem? Hmm.
Could it be anything to do with your pull ups that you are enabling? To enable pull ups on all port pins use the value 255 in the parameters for the function.
Dear Ben,
Now both SPI and I2C (MCP23017 & MCP23S17 ) Flowcode8 modules is working perfectly. Finally I found the solderability issues on my SPI demo board. Now both boards are (MCP23017 & MCP23S17 ) working fine. Thanks for your help.
