Page 1 of 2
Help with STM32 Board choice
Posted: Thu Jan 17, 2019 3:31 pm
by QMESAR
Hi Team.
I am a hardcore Microchip PIC fan and are using them for many years ,however I am getting more and more customers pressing for STM32 device and I
see not my way to use the expensive tool Chain/compilers from STM as a learning curve on STM or even to use for prototyping,
What would you recomend as aminimum to have in V8 and a board with some good IO and perhiperal connections which is supported in Flowcode.
Any hints and advise appreciated,
Re: Help with STM32 Board choice
Posted: Thu Jan 17, 2019 3:54 pm
by LeighM
The Nucleo64 boards are quite cheap, and have pin headers for Arduino shields.
I've used the F4 series boards successfully.
Just choose one that is on the Flowcode 8 target list
Posted: Thu Jan 17, 2019 5:52 pm
by stefan.erni
Hi QMESAR
I used ones a STM32F469 disco Board with touchscreen. it's about 70 euro.....It's very comfortable to use with flowcode.
http://www.matrixtsl.com/mmforums/viewt ... ilit=disco
Posted: Thu Jan 17, 2019 7:11 pm
by QMESAR
Hi Leigh and Stephan
Thank you for the info I will take alook at the boards you mentioned
much appreciated
Posted: Fri Jan 25, 2019 12:05 am
by chad
I have the stm32f446re 180mhz. Great little chip, tons of power. I also have the stm32f303k8 this is the smaller chip. Also great and cheap.
Leigh made a 446re chip target that brings out the other pins besides the arduino headers (works).
Be warned, hardware I2c doesn't work. Some Spi things work, some don't. Most anything that involves timing of any sort are hit and miss. I have no idea about CAN or USB, if I had to guess I would assume they are broken. Components are hit and miss. No way to write to internal flash.
I am at 80 days since first reporting a problem with dmx slave, still no love.
FC support for arm is flakey at best. Not trying to be mean, just a fact. And no one seems to care.
So please get some arms then you can echo my frustrations.
Chad
https://www.amazon.co.uk/STMicroelectro ... +stm32+446
https://www.amazon.co.uk/STM32-NUCLEO-F ... +stm32+446
Posted: Fri Jan 25, 2019 11:13 am
by QMESAR
Hi Chad
Thank you for the links. I started to look at the STM datasheets and if it is as difficult to work with them as understanding the Datasheets
I think I stick to PIC32
Any case thanks again and hope you will get helped with your issues.
Posted: Fri Jan 25, 2019 11:51 am
Hi Chad,
"Still no love" and "no one seems to care" is a bit harsh seeing as we have multiple times fixed problems for you on request.
In fact we have the UART receive frame error working correctly now just not on the EB2 hardware we are using as a test rig. Working fine on the Nucleo board, so hopefully DMX slave should be working for you with the latest updates.
The ST ARM offering is the latest chip pack we have released and so there are always going to be teething problems. Hopefully we can get them resolved as they are reported.
Posted: Fri Jan 25, 2019 7:27 pm
by chad
Two things: 446re target (thanks leigh) and the ws2811 that is still flakey. Although I have figured out work arounds.
When you quoted my comments you selectively glossed over a couple of things. i2c is bit banged. That is a big performance hit to a fast chip.
SPI worked on the apa102 component (great!), but doesn't work on the ssd1351spi. That makes for painfully slow display updates. HIt, Miss.
Interrupt timing values don't match FC numbers. No way to write to internal flash... And these are just the things that I have tried so far.
Put yourself in my shoes, How patient would you be? FC isn't cheap, I bought a tool, not a debugging project. The reason I sound like a pain in the *** is because I keep finding problems and 80 days later they (most) still aren't fixed.
AWSOME!! I will try it out this weekend and let you know. Thank you!!
This is the big one for me.
I get it, but there are still some big issues to be worked out that have been broken for quite a while.
QMESAR: It is just like learning any other new chip. They are cheap and very fast. BTW ST has a fully functional free C IDE.
Give them a shot (hint,hint. the more the merrier) Hell I'll paypal you the $16 to plays with it.
I really like flow code, I just want it to work.
thanks,
chad
Posted: Fri Jan 25, 2019 7:35 pm
by QMESAR
Hi Chad.
I will give the STM's ago the $16.00 is not the problem ,it is an emotional thing sure it is just as learning any other new chip or technology
I have oreder a Nucleo64 board from Aliexpress only ones that deliver to Russia .
We will see can you help with the link to the free C and IDE tool chain that would help a great deal.
Posted: Fri Jan 25, 2019 7:55 pm
by chad
Sure!
https://atollic.com/truestudio/
https://www.st.com/en/development-tools ... ubemx.html
The first is the ide and the second is cube mx. It allows you to set the config registers then send it to the ide.
Chad
Posted: Fri Jan 25, 2019 8:09 pm
by QMESAR
Thanks a million chad.
Posted: Wed Jan 30, 2019 6:45 pm
by mnf
I got one of these boardsto try - I'd got a FC licence to try ARM chips way back (and neither of the two boards I had previously were supported
- so I've not really tried them or FC's ARM support at all before)
- But my question is how to set the clock speed correctly?
Program options doesn't allow me to set 84MHz directly - (too fast) - but what should I set it too? 8MHZ and then tweak the configure settings? None of the options are immediately obvious (even with the descriptive names enabled).
The good - got a blink up and running in minutes (running FC 7 on an ancient and very slow netbook
) - trying to get a UART working gives me random gibberish at 9600 baud - but I'm guessing this is a timing error caused by above?? (Looking through the forums I'm not sure that the UART does work with the usb port (which would be disappointing) - but the fact that I am getting some output makes me more hopeful!)
Posted: Wed Jan 30, 2019 7:22 pm
by LeighM
If your board is a Nucleo or Discovery that we support, then you can select the target FCD and this will set the input frequency for you. As I recall it's 8MHz for the Nucleo.
The config dialog then enables you to set the PLLs and processor and peripherals clocks to whatever suits you.
We don't currently have a method to help here.
ST have CubeMX which helps with the complexity of the clock configurations.
The UART should then take care of itself as regards setting up the baud rate configuration.
I've successfully used the Nucleo board UART loopback through the USB virtual com port, so that does work.
Hope that helps,
Leigh
Posted: Wed Jan 30, 2019 10:40 pm
by mnf
Thanks Leigh,
Setting speed to 8MHz did the trick - and Sudoku solved swiftly and efficiently - and reflected to UART as well
Posted: Wed Jan 30, 2019 11:09 pm
by chad
What stm board do you have?
chad
Posted: Thu Jan 31, 2019 7:58 am
by mnf
Got a nucleo-64 stm32f401 as recommended above... Seem to get a lot of horsepower for very little cash (compared with Arduino (uno,due etc) - though of course clones are available for tiny prices)
Pleased to get it up and running so quickly and easily (been having some difficulties with some Arduino variants of late) - got an oled (1306) running on i2c as well.
Spent a bit of time looking for hardware i2c - and found an 'initialise' though information doesn't seem to be that readily available - I guess this is just too much of it out there and Google isn't giving me what I wish for.
I couldn't find the correct board when signing up to the mbed website - but very early days (and as mentioned was working on a slooooww computer which made doing anything rather frustrating)
I also notice that Windows has failed to install a driver for the stlink debugger - which looks like a useful feature - so some more work needed there too.
Posted: Thu Jan 31, 2019 9:47 am
by LeighM
Glad to hear you have it up and running.
Flowcode I2C support is limited to Software only at the moment on ST ARM,
but it is on my list to add hardware support, hopefully I can get this done in the next week or so.
The ST website has quite a number of free downloads, ST-LINK, USB drivers etc.
Leigh
Posted: Wed Feb 06, 2019 7:36 pm
by chad
Hardware I2c would be really great!
chad
Posted: Sun Feb 17, 2019 2:44 am
by chad
QESMAR, Did you get your arm boards?
chad
Posted: Sun Feb 17, 2019 6:36 pm
by QMESAR
Hi Chad waiting for them from Aliexpress
I will need your help once I have them
Have good one
Posted: Mon Feb 18, 2019 7:34 pm
by chad
I'm making it up as I go..
The guys are fixing stuff on the arms. They are getting better and better...
chad
Posted: Wed Feb 20, 2019 2:50 pm
by QMESAR
chad,
Ben and Leigh will fix everything I know them for years ,be sure of that it is only their time is many times very limited but at
the end they fix always every thing
Posted: Wed Sep 11, 2019 2:33 pm
by Alkaline
Hi everyone
for a new project we would like to try using a st32 microcontroller instead of the classic pic32 we are using now.
Reading the forum a little and checking the various chips that are supported, I identified this model as an ideal candidate
STM32F411CEY6TR or STM32F411VEH6
The protocols that I must use are i2c master (software) and usart (hardware).
reading the various application notes of the st I saw that this family is compatible with
the usb dfu bootloader. Is it possible using their program to load the source generated by flowocode via usb?
Do you recommend other chips?
thank you
Posted: Wed Sep 11, 2019 2:36 pm
by Alkaline
Hi everyone
thank you
Posted: Wed Sep 11, 2019 3:12 pm
by LeighM
Flowcode will directly program via an ST-LINK device,
or the ST UART based bootloader (CLI and GUI) will work with Hex files generated from Flowcode.
The last time I looked there was no easy way of converting Flowcode output to DFU format for the ST USB DFU programmer,
so that has limited use.
It can however be easily used to extract a master image from one board, via USB, and then used to program others via USB.
If that helps.
Leigh
