Same updates reoccurring after download completion.[Fixed]
Posted: Mon Jan 21, 2019 12:18 pm
After selecting full database, the following updates keep appearing after downloading and reloading flowchart:
The components current level are also showing non genuine.
Re: Same updates reoccurring after download completion.
Posted: Mon Jan 21, 2019 1:15 pm
We did create a problem with the RPI targets. We thought we had fixed it but maybe this is just if you didn't download updates while the broken files were available.
You should be able to delete the contents of your "C:\ProgramData\MatrixTSL\FlowcodeV8" folder to effectively start again.
Posted: Mon Jan 21, 2019 1:39 pm
Benj wrote:You should be able to delete the contents of your "C:\ProgramData\MatrixTSL\FlowcodeV8" folder to effectively start again.
Yes, that has fixed it.
Thank you.
Posted: Mon Jan 21, 2019 5:59 pm
by STibor
Benj wrote:Hi Martin,
Hello!
After deleted C:\ProgramData\MatrixTSL\FlowcodeV8 folder, still remain sticky update files.
Same files as Medelec35.
Posted: Fri Jan 25, 2019 12:32 pm
Same files
Same Problem is back for me as well.
Deleting
was not a permanent fix.
Posted: Fri Jan 25, 2019 7:30 pm
by chad
I'm Seeing the same thing.
Chad
Posted: Tue Jan 29, 2019 6:47 am
by jgu1
Hi all!
Is this a bug we have to be aware of or is it fixed, please?
Br. Jorgen
Posted: Tue Jan 29, 2019 11:21 am
I've had another go and hopefully have now correctly resolved the problem.
Posted: Tue Jan 29, 2019 12:31 pm
Confirmed sorted.
Thank you.
Re: Same updates reoccurring after download completion.[Fixed]
Posted: Wed Jan 30, 2019 8:09 pm
by chad
Second conformation. it seems to be fixed for me too.
Chad
