Problem with upload codes for ECIO40P
Posted: Sat Feb 09, 2019 2:31 pm
by Monie Jacobsen
Hi!
Got a new computer
Technical data:
Windows v10
Intel (R) Core (TM) i7-6700 CPU @ 3.40GHz
Installed RAM: 32.0 GB
64-bit operating system
Hardisk type DDS
The problem is that Flowcode v8 did not can upload to ECIO40P
Code example:
FlowcodeECIO_Test.fcfx
(5.74 KiB) Downloaded 237 times
Compiler Messages
Target folder: C:\Users\Bruger\DOCUME~1\SOLART~1
Source name:   C:\Users\Bruger\Documents\Solar Tracker 09-02-2019\FlowcodeECIO_Test.fcfx
Title:
Description:
Device:        PIC.18F.ECIO-40
Generated by:  Flowcode v8.1.1.11
Date:          Saturday, February 09, 2019 14:01:36
Users:         1
Registered to: monie jacobsen
License key: X6U4U7
https://www.matrixtsl.com
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\bin\xc8.exe  --chip=18F4455 "FlowcodeECIO_Test.c" --MSGDISABLE=359,1273,1388 --CODEOFFSET=800h --ROM=default,-0-7FF
Microchip MPLAB XC8 C Compiler (Free Mode) V1.45
Build date: Nov 15 2017
Part Support Version: 1.45
Employing 18F4455 errata work-arounds:
 * Corrupted fast interrupt shadow registers
 * No stopping on H/W breakpoints after NOP2
Memory Summary:
    Program space        used    F2h (   242) of  5800h bytes   (  1.1%)
    Data space           used    2Dh (    45) of   7FFh bytes   (  2.2%)
    Configuration bits   used     7h (     7) of     7h words   (100.0%)
    EEPROM space         used     0h (     0) of   100h bytes   (  0.0%)
    ID Location space    used     0h (     0) of     8h bytes   (  0.0%)
    Data stack space     used     0h (     0) of   7A0h bytes   (  0.0%)
You have compiled in FREE mode.
Using Omniscient Code Generation that is available in PRO mode,
you could have produced up to 60% smaller and 400% faster code.
See http://www.microchip.com/MPLABXCcompilers for more information.
C:\Program Files (x86)\Flowcode v8\tools\DoNothing\DoNothing.exe
Launching the programmer...
C:\Program Files (x86)\Flowcode v8\tools\mLoader\mLoader.exe  -ecio40 "FlowcodeECIO_Test.hex"
C:\Program Files (x86)\Flowcode v8\tools\mLoader\mLoader.exe reported error code 255
FINISHED
The same problems as above apply for MIAC dsPIC type: MI5409 and MIAC (Arduino) type: MI5466
It is impossible for me to be able to upload codes to these 3 units
(67.2 KiB) Downloaded 1090 times
Also, can't get enough on trying to install Driver device
Do you / have suggestions for what needs to be done to make these units seem stable.
Have tried very much but without success;-)
I will be very happy if someone will help with the above problems.
Re: Problem with upload codes for ECIO40P
Posted: Sun Feb 10, 2019 11:49 pm
Hi Monie.
Hmm I got a similar issue when installing the ECIO40P driver on my home PC using the driver packaged in Flowcode. I'll investigate why this is failing.
For now use this driver from the website. It worked for me.
https://www.matrixtsl.com/resources/get ... e.php?id=3
Posted: Mon Feb 11, 2019 9:45 am
by Monie Jacobsen
Hi Benj
Really many thanks for looking at the problem.
The Driver from the website. It worked not for me.
But when upload is complete, Flowcode shuts itself down.
SolarTrackerECIO40P-09-02-2019.fcfx
(280.91 KiB) Downloaded 214 times
- I cannot upload this file to ECIO40P at all...
Hope much we will solve the problem.
Posted: Mon Feb 11, 2019 11:37 am
by Monie Jacobsen
Hi Benj
Cannot upload File from Flowcode v8 to MIAC dsPIC type: MI5409 and MIAC (Arduino) type: MI5466 or ECIO40P
It is impossible for me to be able to upload codes to these 3 units.
Have tried the recommended Driver for ECIO40P but could not upload coder to this device.
What should I do to make the devices work from above?
Do you have any news about this?
Posted: Tue Feb 12, 2019 11:59 am
by Monie Jacobsen
To Flowcode technician / programmers
Have Miac dsPIC work!
But cannot make ECIO40P work.
And if I try to get the ECIO40P, then Miac dsPIC so does not works more!
And must reinstall Flowcodw v8 again to make Miac dsPIC work.
What goes wrong. I just have to install your Flowcodw v8 installation files?
Posted: Thu Feb 14, 2019 5:11 pm
by Monie Jacobsen
Hi Benj
Can Flowcode v8 not run Computer with the following data?
1: Installeret RAM 32.09 GB
2: DSS Hard Drive:
(9.12 KiB) Downloaded 981 times
