Servo controller channel number property.
- Been thanked: 4 times
In the properties of the servo controller, the channel has the number 1, and in the properties of macro 0, I suggest making the same channel numbers.
- (30.12 KiB) Downloaded 584 times
- (40.11 KiB) Downloaded 584 times
Re: Servo controller channel number property.
The Servo motor property has number of servos 1-8 and then the servos are all referenced 0-7. This is a common programming scenario and we have tried to make this obvious i.e. making the Connection and Trim properties numbered from 0 etc.
Changing the number from 0-7 to 1-8 will likely break a lot of existing programs and also be confusing to anyone who is used to the numbering from 0 programming paradigm.
