I have a simple counter from 1 to 20. But I need the counter diviede by 10. Counter is A_byte and the 10th part is A_real. The simulation works correctly. But the microchip has different ideas about this 'problem'. All numbers are correct, except A_byte=14 and A_real should be 1.4. The reality is, see picture
Kind regards
Jan
How is this possible?Division by 10 easy?
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
- Jan Lichtenbelt
Re: Division by 10 easy?
In the meanwhile I found the solution. All real numbers have positive rounding errors, while 1.4 has been calculated with an negative error with results 1.399...... The 3 lift characters will result into 1.3 instead of 1.4
Kind regards
Jan
Kind regards
Jan
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Hi Jan,
If you just want to display the divided number rather than do any maths on it, then you could do something like this:
1) convert the integer to a string:
2) display the first part of the string:
3) display a "."
4) display the last digit:
Steve.
value_as_string = ToString$(my_int_value)
Left$(value_as_string, Length$(value_as_string)-1)
Right$(value_as_string, 1)
Steve.
- AbhijitR
- Has thanked: 284 times
- Been thanked: 80 times
Hello! Jan
Many thanks for this post, some what life saving for me.
Thank you again.
Abhi
Any idea how to round off the answer 12.3 to 12 and 12.6 to 13, I think to round off to the nearest value before and after 0.5Jan Lichtenbelt wrote:In the meanwhile I found the solution. All real numbers have positive rounding errors, while 1.4 has been calculated with an negative error with results 1.399...... The 3 lift characters will result into 1.3 instead of 1.4
Thank you again.
Abhi
Hi Abhi,AbhijitR wrote: Any idea how to round off the answer 12.3 to 12 and 12.6 to 13, I think to round off to the nearest value before and after 0.5
I believe the round() function will do what you are after.
If you open a calculation box, then select fx, you can scroll down to round().
- AbhijitR
Hi! Martin
Abhi
No exaggeration, you are more or less WIKI for FC, thank you once again for that quick reply.medelec35 wrote: If you open a calculation box, then select fx, you can scroll down to round().
Abhi
