hi all,
apology's if this is posted in the wrong section, im aiming to use 3 analogue inputs in turn to read data but want to connect all three to the same output in turn whats the easiest way to connect all three inputs to a single output without interfering with each other,i had thought initially of using diodes but the 0.7v diode drop will interfere with the adc reading
regards bob
multi channel anologue
- Has thanked: 101 times
- Been thanked: 25 times
- Has thanked: 460 times
- Been thanked: 523 times
Re: multi channel anologue
Hi Bob
How about an analougue multiplexer ?
Have used the ADG609 before
https://www.analog.com/media/en/technic ... 08_609.pdf
