RX1602A4-BIW-TS lcd
- Has thanked: 2 times
- Been thanked: 3 times
RX1602A4-BIW-TS lcd
Good morning Matrix people. I bought this RX1602A4-BIW-TS 2x16 lcd display based on the ST7032i chip. So far no one of the lcd IIC dispays I tried worked...Did I do something wrong or the code it just not compatible? And if is not, can you write a new component please?
Best regards
Sakis
Best regards
Sakis
Re: RX1602A4-BIW-TS lcd
Hello Sakis,
I don't beleive we currently support the ST7032 driver IC but yes it should be possible to add it.
Are you able to send us a display to help develop the code and for testing purposes?
If not I can have a go at a component but it makes things more tricky to get right.
Hi Sakis,
Excellent that's great, here's our address.
Ben Rowland
Matrix TSL
The Factory
33 Gibbet Street
Halifax
HX1 5BA
Ben Rowland
Matrix TSL
The Factory
33 Gibbet Street
Halifax
HX1 5BA
Hello Sakis,
Display received, many thanks for that.
I'll get to work on it ASAP and let you know when I have some progress.
Hopefully later this week.
Component has now been created and tested. I've now pushed it to the update system, just do a full database update in v8 and you should get the new component.
I had problems using internal weak pull ups on the I2C pins, you need external 10K pullups for it to work nicely.
Let me know how you get on.
