CLKOUT on the 18F66K80
Posted: Sat Feb 15, 2020 9:09 pm
I want to run the 18F66K80 at full speed (64Mhz), preferably using an external Xtal (but could use the INTOSC if need be), but I also want a CLKOUT at preferably 5Mhz (but could possibly push all the way up to 16Mhz) to run a few external components in sync.
Is this possible? I'm a little confused as the CLKOUT pin is on A6, bit the OCS1 & OSC2 pins are A6 & A7.
Also, how do I scale the CLKOUT frequency to 5Mhz (or 16Mhz if I really have to)?
I think I need to use the EC3IO, but not sure on how to implement it.
