Hello Benj
The method you provided didn't work.
The software makes an error when compiling.
In file included from C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\includes.c:647,
from C:\Users\RAB\Desktop\check\Z\Flowcode1.c:351:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/AVR\AVR_CAL_PWM.c:179:6: warning: #warning "PWM Channel Uses Resource Timer 1"
In file included from C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\includes.c:669,
In file included from C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\includes.c:692,
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/AVR\AVR_CAL_PWM.c:238:7: warning: #warning "PWM Channel Uses Resource Timer 2"
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\/AVR\AVR_CAL_PWM.c:495:3: warning: #warning "Period control register not available on target device, period will default to 255 + 1"
C:\Users\RAB\Desktop\check\Z\Flowcode1.c: In function 'main':
C:\Users\RAB\Desktop\check\Z\Flowcode1.c:939: error: 'TCCR2B' undeclared (first use in this function)
C:\Users\RAB\Desktop\check\Z\Flowcode1.c:939: error: (Each undeclared identifier is reported only once
C:\Users\RAB\Desktop\check\Z\Flowcode1.c:939: error: for each function it appears in.)
Error returned from [avr-gcc.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\avr\batchfiles\avra.bat reported error code 1
