SCADA POTENTIAL
Posted: Wed Apr 15, 2020 10:41 pm
by pantelisthrylos7
Hi there!
Is it possible to have a SCADA runtime with the ability of the end-user to switch among different dashboard or system panels?
Re: SCADA POTENTIAL
Posted: Wed Apr 15, 2020 10:57 pm
I don't think what you want is currently possible but you can do similar things using a few tricks.
1) You can move the camera on the 3D panel using the simulation API commands.
https://www.flowcode.co.uk/wiki/index.ph ... ion.Camera
2) You can make components visible and invisible either individually or in groups again using simulation API commands.
https://www.flowcode.co.uk/wiki/index.ph ... _Component
If you want any help or examples then let us know.
Re: SCADA POTENTIAL
Posted: Thu Apr 16, 2020 10:29 am
by pantelisthrylos7
Thank you Ben,
I will try these tricks and check what I can use. It would be wonderful if indeed there was such an ability!
My Regards
