MODBUS RTU help
S_V
Has thanked: 3 times
MODBUS RTU help
Post by S_V »
this is Component macro in MODBUS Slave (SCADA)
could you kindly share how to retrieve the info ( INDEX 0 thru INDEX 3)
GetLastIncoming
Gets a value from the last incoming command.
Index 0 = 0 Read / 1 Write
Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register
Index 2 = Address
Index 3 = Number
Parameters
This macro has no parameters
Return value
UINT
Thank you
SV
Re: MODBUS RTU help
Thanks for letting us know.
Hopefully should be fixed for you now via the update system.
