Problems with Code Profiling
Bruno
Been thanked: 21 times
Post by Bruno »
Hi all
I have a problem with "code frofiling", in FC7 it works correctly, instead in FC8 it indicates a cross on all icons,
as shown in the photo. Does code frofiling work differently in FC8?
Anyone have the same problem?
thanks
best regards
(62.69 KiB) Downloaded 58 times
Re: Problems with Code Profiling
Hi Bruno,
Thanks for letting us know. We do know about the issue and there is a workaround while we produce a fix. If you select "build...compile to c" from the menu before running the simulation, then the code profiling data will be displayed correctly. See here:
viewtopic.php?f=78&t=22149
Steve.
Bruno
Post by Bruno »
Thanks Steve, I have tried and it works :D :D
best regards
