Arduino Uno USB Serial
Posted: Sat Jun 13, 2020 3:50 pm
by gavo4
Hi All,
I have come across an issue on the Arduino Uno, for some reason the USB Serial does not work.
I have used the USB_Serial1 component and I have also:
* Initialised the USB
* I then used the USB Serial Send String
When I run the flowchart simulation I see the USB Serial component showing a green arrow on/off to show the data is been sent, however I can't see the data in serial monitor in Arduino or TeraTerm. One of the questions I wanted to ask is how do you set the Baud-rate?, is there perhaps a default baud rate which is used by the component?
Any help would be greatly appreciated,
Gavo
Re: Arduino Uno USB Serial
Posted: Sat Jun 13, 2020 3:59 pm
by kersing
The Arduino UNO has no USB integrated into the controller but uses a uart port to drive a serial to USB chip on the board.
So you need to use a serial (uart) component, not the USB component.
Posted: Sun Jun 14, 2020 9:03 am
by gavo4
Thanks so much - all working now
