Fingerprint sensor terminology
Posted: Wed Aug 12, 2020 5:35 pm
I've been reading the datasheet for the R503 fingerprint sensor (GROW) for a while. (https://www.dropbox.com/sh/epucei8lmoz7 ... AhzAa?dl=0 )
This is a Chinese device and the datasheet doesn't give me all answers I need.
There is different terminology and there aren't examples for the way things are supposed to work. (maybe because English isn't my native language that I don't understand everything)?
I've read that some people have worked with these sensors already so I need some help finding the proper way to use it.
I always try to find out how things work, rather then find an example and implement this.
Can somebody please help me with these questions?
What's the difference between a "finger image", a "character file" and a "template"?
As I see it, please correct me if I'm wrong, a finger image is an image the sensor collects from it's sensor-window? So what the sensor really sees?
A character is (according to me) a set of points in a finger that is specific for that finger??
A template, again, I'm pretty sure I'm wrong... is a few characters combined to get a better, more accurate idea of the registered finger?
How can I:
1- enroll a new finger?
2- make sure it is most accurate
3- check a certain fingerprint if exists in the database (flash)
These are the commands I think I need to get this done:
GenImg Collect finger image
Img2Tz To generate character file from image
Match Carry out precise matching of two templates;
Search Search the finger library
RegModel To combine character files and generate template
Store To store template;
LoadChar to read/load template
UpChar to upload template
DownChr to download template
UpImage To upload image
DownImage To download image
DeletChar to delete tempates
ReadIndexT
able Read fingerprint template index table
Empty to empty the library
TempleteNum To read finger template numbers
GetImageEx Fingerprint image collection extension command
Has someone ever used this set of commands to get the sensor working?
Can someone help me please?
The new sensor is on it's way from China so I can not play with it at this point, but I want to make sure I have a draft for a Flowcode file ready as it arrives..
Thanks already!
How can I:
ReadIndexT
Thanks already!
