ADC6 ATMEGA328P-AU TQFP
Posted: Sun Oct 18, 2020 5:21 pm
by ChrisT66
which port in FC is the one of the ADC6? On the chip view in FC the reset pin is PC6...
Thanks for a feedback!
Chris
Re: ADC6 ATMEGA328P-AU TQFP
Posted: Mon Oct 19, 2020 11:51 am
Hi Chris,
ADC6 and ADC7 are not tied to digital Port Pins and are instead on their own dedicated pins.
Posted: Mon Oct 19, 2020 12:23 pm
by ChrisT66
Okay thanks for the answer! Does this mean that I can only read the ports via a C routine in FC?
Posted: Mon Oct 19, 2020 12:58 pm
If you select the ATMEGA328PTQFP as your target device then it should allow you to select ADC pins 6 and 7 on ADC enabled components.
Posted: Mon Oct 19, 2020 3:04 pm
by ChrisT66
Super thanks!
It would be great, if in later versions it is possible to read the voltage (for example) of an analog input directly without placing a "non-existent" component.
