Graphical / Touchscreen display
Posted: Sun Oct 25, 2020 6:41 pm
by billduck
I would like to become familiar with programming a Graphical / Touchscreen display for use with the UNO or Mega.
So I am look for recommendations for the hardware, and some sample code (FC8) to get started.
what I can find is here but sorting thru it is a challenge.
https://www.matrixtsl.com/wiki/index.ph ... Graphical)
Thanks in advance.
Re: Graphical / Touchscreen display
Posted: Sun Oct 25, 2020 7:14 pm
by mnf
I'm currently using a Nextion display - works very well, but cheating a bit, since the display is actually doing the heavy lifting.
Working up to the Gameduino (again the display is really doing a lot of the hard work)
See
https://m.banggood.com/search/Nextion.html for example - but more there are different levels of display with the higher levels offering more functionality..
Posted: Sun Oct 25, 2020 7:32 pm
by billduck
Thanks. Looking for that display within the component list for Flowcode8. Is it listed in another name?
Posted: Sun Oct 25, 2020 7:51 pm
by mnf
It doesn't have a component - all the display layout is done on a PC (and programming/debugging) - The display communicates with the Arduino via UART.for example it sends a string if a button is'pressed' or the Arduino can send a string to change a gauge indicator, or some text etc.
It's pretty easy to use - I can give more examples if needed or work you through a use case.. I'm thinking of a component for it, but for many uses it probably doesn't need one.
Posted: Sun Oct 25, 2020 7:55 pm
by mnf
Try the programmer, simulator from
https://nextion.tech/nextion-editor/ and see if out can do what you are after in a display.
