XPT2046 FC8
Posted: Wed Jan 27, 2021 12:57 pm
by jgu1
Hi!
I am playing with an ILI9341 display with touch. I use the XPT2046 SPI. Unfortunately I have no luck, nothing happen when I touch the display. My display write 639 and 479 X and Y all time. I see the are a pin availbe on touch SPI: T_IRQ, should this not connectes?
Can anyone see what I have done wrong in my testprogram, please and have anyone some experience with the touch?
Thank,´in advance
Jorgen
Re: XPT2046 FC8
Posted: Wed Jan 27, 2021 5:43 pm
by jgu1
Solved :D
Switch the SPI from Channel to sofware and it work. SO NICE :wink:
Jorgen
Re: XPT2046 FC8
Posted: Thu Jan 28, 2021 5:49 pm
Hi Jorgen,
Thanks for letting us know. Strange the hardware SPI wasn't working well for you. The SPI mode was setup wrong before so maybe this has been fixed via a recent component update?
Re: XPT2046 FC8
Posted: Thu Jan 28, 2021 8:01 pm
by jgu1
Yes could be Ben, but work fine..... You guy´s make a good job :lol:
I already made some test. I made it in FC8 because I want to implement in an preveius project. Look forward to test in FC9 :wink:
MAybe you have time to look in my testprogram. I have made a buttom in the display and when I press inside the buttom I want it to do something. As you see, I said:
If: X > 56 AND X < 100 AND Y < 90 AND Y > 50 then do. IT is working nice, but is this the only way or is there a more simpler way to do it? I see sometime in other projects they calibrate the display, have this something to do with a system for use as above?
Hope you understand what I mean :wink:
Jorgen
