Sorry to put it here but I had no choice:
I can't login on new flowcode 9 forum, although I can login to the new https://www.flowcode.co.uk web site .
When I go to forum login I filled in the same credentials but had no luck.
username: miggarc
Can you please solve this...
Anyway, I will ask here about what I should be asking there (if your system permitted me to do it):
Flowcode 9 and ESP32: Can I develop programs in flowcode 9 targeting ESP32 as a microcontroller,
besides its communication capabilities (wifi, bluetooth...) ?
Or, on the contrary, ESP32 can only be used by flowcode as a communication module ?
Thanks in advance,
Miguel Garcia
Thanks in advance,
Miguel Garcia
Electronics Technician
Electronic Systems Developer
Thanks in advance,
Miguel Garcia
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: I can't login on new flowcode 9 forum
Please try login to the flowcode.co.uk site, then go down to the "change password" option on the main account homepage once it loads, and try changing your password. Hopefully this will change your password on the forums too.
If it does not then please use the contact form here:
https://flowcode.co.uk/contact/
And i will pick it up and contact you directly via email to change the passwords.
No, it did not work.
I changed the password but as soon as I tried to login in the new forum,
besides the wrong credentials alert I was congratulated with:
"You exceeded the maximum allowed number of login attempts.
In addition to your username and password you now also have to pass the CAPTCHA test."
(on the 1st try) .
As on the same post I also asked about flowcode 9 and ESP32, please answer this question here
(because I don´t have much more time to wait for access to the new forum and then ask the same question there and wait again
for an answer) . In other words, this is like to buy or not to buy your professional flowcode 9 and several Feature Packs, so I need your answer.
lots of thanks in advance,
Miguel Garcia
(on the 1st try) .
Miguel Garcia
Thanks in advance,
Miguel Garcia
Thanks in advance,
Miguel Garcia
