ADC internal Vref Activate
Posted: Thu Oct 14, 2021 5:16 pm
by RABO2320
please guide me
in the FC v8
I want to enable the internal reference voltage for ADC but there is no such option in ADC properties.
I even referred to the AVR_CAL_ADC.c file and:
changed the REFS1 & REFS0 bit in the ADMUX registry but it didn't work.
Re: ADC internal Vref Activate
Posted: Fri Oct 15, 2021 8:28 am
by LeighM
What device are you using?
Posted: Fri Oct 15, 2021 11:35 am
by RABO2320
I used AVR ATMEGA 8A.
Posted: Sat Oct 30, 2021 4:43 pm
by RABO2320
Posted: Sat Oct 30, 2021 8:45 pm
by chipfryer27
Can you be a bit more specific? Do you mean the AD7680 component or the generic Potentiometers? If the latter it's very simple under Properties.
Edit....
Posted before finishing my sentence (Doh..) If AD7680 then as far as I'm aware it only uses the Power Supply as reference
Posted: Sun Oct 31, 2021 4:19 pm
by RABO2320
No, I do not use the AD7680 component.
I am using one of the ADC microcontroller input pins.
I input a sampled voltage to the ADC microcontroller input pins.This voltage is between zero and five volts.
I want to use 2.56 volts is the internal reference voltage for the ADC reference voltage.
Posted: Sun Oct 31, 2021 9:08 pm
Hi RABO2320
Can you paste tthe following within windows explorer:
C:\ProgramData\MatrixTSL\FlowcodeV8\CAL\AVR
Then replace the existing file with the attached version.
You will need to reload the flowchart after.
The file is untested as I have not got the same target device to test on.
You will need to change the reference properties to Vref +pin.
Instead of Vref +pin, hopefully it will work with 2.56 internal reference?
Posted: Tue Nov 02, 2021 9:02 am
by RABO2320
The file you ATTACHMENTS does not work properly and gives the following error in the simulation:
- screen.png (416.24 KiB) Viewed 8906 times
Posted: Tue Nov 02, 2021 9:35 am
Sorry, It was a typo.
Can you try the attached and see if it works?
Posted: Wed Nov 03, 2021 4:09 pm
by RABO2320
Thank you for your guidance.
This file worked perfectly.
Posted: Wed Nov 03, 2021 7:08 pm
That's excellent.
Thanks for letting me know.
