Send sting via rs232
Posted: Thu Aug 23, 2007 5:25 pm
by ALAN_26
HELLO
HOW can i send a string via RS232 , rs232 only sends bytes variables or int variables !
And how can i put a numeric string back in a int or byte variable ?
anyone got any idea ?
Thanks in advance
Posted: Fri Aug 24, 2007 10:21 am
To send a string via RS232 you can simply use the following.
"HELLO WORLD"
or you can pass a string variable as the parameter.
To receive a string is a little more complicated.
first you need to create a while loop a length variable and an index variable.
set the index to 0
set the length to the length of the string eg 6 characters
loop while index < length
receive rs232 character and store into string[index]
increment index
