I am new to C++ and I am trying to learn it using FLOWCODE.
I wrote a short program to add 4+4 in C and display it using FLOWCODE. This is the end of the program.
//Initialisation
//Interrupt initialisation code
option_reg = 0xC0;
//C Code
//C Code:
FCV_RE = 4 + 4 ;
//Output
//Output: RE -> PORT A
trisa = 0x00;
porta = FCV_RE;
mainendloop: goto mainendloop;
I wrote a similiar program using the FLOWCODE calculation box and the only difference was
//dan
//Calculation:
// RE = 4 + 4
FCV_RE = 4 + 4 ;
To my eye, the C code generated is identical yet the output to PORTA is different. Am I missing something.
Thanks for any help.
Daniel Pollit
Toronto, Canada
Trouble Using C code in FLOWCODE
Hi Steve,
The code in the Calculation Box is
RE = 4 + 4
When I run the program using C++ code
FCV_RE= 4 + 4 ;
the RE Variable stays at zero throughout and finally, the OUTPUT to PORTA of RE displays zero.
When I substitute or add the Calculation Box as above, and execute the program, the value in RE becomes 8 as the Calculation step is run and in the OUTPUT to PORTA the Led indicating 8 indeed lights up.
Thanks for any light you can shed.
Daniel Pollit
Toronto, Canada
RE = 4 + 4
FCV_RE= 4 + 4 ;
Daniel Pollit
Toronto, Canada
