Greater Then
Posted: Fri Nov 24, 2006 12:53 pm
by PaulV
I am trying to create a system to control a can retort.
I can't figure out the syntax for the > (greater then) symbol in calculations.
I want to use a 'greater then' condition on the calculations, but it is not accepting the symbol.
Any ideas?
Posted: Fri Nov 24, 2006 5:43 pm
Hi Paul
I take it your using flowcode to program your system.
Are you using a decision box in which case you will need
Or are you using a C Code box in which case you will need
If you are using a calculation box then it will fail as this is a comparison not a calculation.
Posted: Mon Nov 27, 2006 11:04 am
by Steve
You can use a greater-than symbol in a calculation icon like this:
y = (x > 3)
This will set y to 1 (true) if x is greater than 3, otherwise it will set y to 0 (false).
CAN
Posted: Mon Nov 27, 2006 3:43 pm
by goldwingers
Hi steve,
Please excuse the content, but what is CAN, is it a new divice to open a tin of Beans? or something totally different, I can see you use a car door on your grapic in V3, but i couldnt find any reference to what it is or does within the help file.
Ian
Posted: Mon Nov 27, 2006 4:03 pm
by Steve
