This weekend I played around wit the Custom Component and the Custom_Code.c you provide. So I tried to use the Funct3 that returns the sum of 2 values:
char Funct3(char nPara1, char nPara2)
/*Macro_Funct3_Start*/
return (nPara1 + nPara2);
/*Macro_Funct3_End*/
It seemed pretty easy, so I set up a flowchart with a Component Macro that calls the function Funct3 with 2 given values and stored the return value in a variable. To "see" what was calculated, I took an LED array and put in the SUM. And now it is getting confusing: as long as I simulated at no time was the calculation right. e.g. 1+1 = 2 but in the simulation it was 4 or 92 and I had no clue why it did so. As soon as I programmed the real Atmega32 it worked, so I assume this is / may be a bug in Flowcode OR the Custom Component is not finally implemented. Or did I miss something?
Nils
