Prescaling the clock and creating a delay
Posted: Tue Nov 27, 2007 10:34 am
by DaveRoberts
I am totally new to PICS and would like to create a time delay of between 5 or 10 seconds. Obviously with a clock speed of 3MHz a simple count is a big number. I am aware that the clock can be prescaled to give a 1:256 ratio meaning the count would be substantially less. The only problem is I do not know how to write the code for this. Can anyone help??
Posted: Tue Nov 27, 2007 10:48 am
The easiest way to create a second delay is to create a function with a byte and an integer variable.
byte - inner_loop
int - outer_loop
then do something similar to the following.
for (outer_loop=0;outer_loop<3000;outer_loop++)
for (inner_loop=0;inner_loop<250;inner_loop++);
//Note this code is designed to work with a 3MHz crystal.
To create delays of more then one second simply add another for loop around the second delay structure.
If you need a very precise second timer then your better off using the Timer0 interrupt.
Time delays in Assembler.
Posted: Tue Nov 27, 2007 7:44 pm
by KeithSloan
For time delays in assembler I recommend PicLoops. It takes all the hardwork away http://www.mnsi.net/~boucher/picloops.html
Keith
Posted: Wed Nov 28, 2007 8:10 am
by DaveRoberts
This does not seem familiar to me. I did forget to mention that I am using the PIC16F84A. I assume the code you have sent me here is in C?
Dave
Posted: Wed Nov 28, 2007 10:23 am
Hello Keith
That software looks great. Wish I had something like that back when I was writing assembler code.
Posted: Wed Nov 28, 2007 10:31 am
Hello Dave
The example code that Keith sent is in assembler. It should work fine with MPLAB or other similar PIC compilers. It will also work with your 16F84A chip.
