Launching the compiler...
H:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic16.flowcode.exe -v -t PIC12F683 "PWM 5 tot 95 proc.c"
BoostC Optimizing C Compiler Version 6.70 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
PWM 5 tot 95 proc.c
Starting preprocessor: "H:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "J:\PIC data en sotware\PWM 5 tot 95 proc.c" -i "H:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC12F683 -la -c2 -o "PWM 5 tot 95 proc.pp" -v -d _BOOSTC -d _PIC16
PWM 5 tot 95 proc.c success
success
Return code = 0
H:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostlink.pic.exe -ld "H:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\lib" libc.pic16.lib flowcode.pic16.lib "PWM 5 tot 95 proc.obj" -t PIC12F683 -d "J:\PIC data en sotware" -p "PWM 5 tot 95 proc"
BoostLink Optimizing Linker Version 6.70
Warning unreferenced functions removed:
FCD_PWM0_Disable in: J:\PIC data en sotware\PWM 5 tot 95 proc.c
FCD_PWM0_ChangePeriod in: J:\PIC data en sotware\PWM 5 tot 95 proc.c
Building CASM file
Memory Usage Report
RAM available:128 bytes, used:11 bytes (8.6%), free:117 bytes (91.4%),
Heap size:117 bytes, Heap max single alloc:84 bytes
ROM available:2048 words, used:183 words (9.0%), free:1865 words (91.0%)
success
Return code = 0
Launching the programmer...
Hello, what must i do to get my pwm working, on the 12F683.
versie 3.2.2.40
groet, Danny
- Has thanked: 17 times
- Been thanked: 10 times
Re: unreferenced functions removed
Hello Danny
The warnings are simply stating that these functions are not used in your program.
It is nothing to worry about.
If the PWM is not running then make sure that the program has the correct configuration. Eg XTAL or RC mode and Watchdog Off.
I think that these thing are correct, in the expert config in ppp, see jpg, still pwm is not working
Hello Danny
Please can you try this program for me.
If the PWM is still not working when you send this program to the chip then there may be a small problem in either the definition file or the PWM component itself. Either way let us know and we will get on top of the problem for you.
- PWM Test.fcf
- (3.5 KiB) Downloaded 306 times
It was a mistake in my flowcode, i tried to connect a diffrent output to my PWM.
Last moth i have been to antwerpen for a flow code Elektor cursus, and last week buyd E-blocks, what works great.
Groeten Danny
Groeten Danny
