how to use RS485 communication and SPI expander
Posted: Thu Aug 21, 2008 10:47 am
hi friends,
I am using the pic16f877a for the RS 485 master slave communication as per the data sheet the SPI or the I2C are the serial communication with the peripherals as a master slave logic, but currently i am using the master slave communication between two pic 16f877a chips, since I need additional I/O ports for my project I am insist to use the expanders MCP23S17, . but I need to connect the master and slave through the PORTC, for RS 485 communication, but the SPI and I2C caonfiguration also in the PORTC , in this case how to manage the RS 485 communication and SPI for the expander at the same time is it possible to use at the same time
thanks
Saran
thanks
Saran
