It appears that the choice of speed selected in the `expert setup` is not what you (me!) expects to happen.
Running a small test program which displays a few characters and increments a displayed No. which counts how many times the program cycles through. I have also got an `input` to zero the No. to be used on the ver3 dev board.
After 200 cycles the program ends, so i can then run and time the program choosing the different `chip speeds` and selecting different `expert setup`oscillator settings. Then timing the program until it ends. The results are attached . Incidently these results are from using the ver3 dev board not the flowcode program on the pc.
Q. why does choosing a FASTER chip speed result in a SLOWER running program.
Q. why does choosing the oscon fast setting setup for 32mhz internal oscillator, be SLOWER than the
HS setting.
Hoping that you can help me here as i am at my witts end
Q. Is it possible to run the LCD on the board at a different speed to the flowcode program
Q. How can i be sure i am getting the speed i thought i was setup for
I have not the use of an actual oscillascope.
Maybe you could put together a simple program for those of us that have a need, for us to run that you know that has a certain time span. It could then be used to make comparisons with.
