compile Failing on linker
Posted: Sat Dec 27, 2008 2:53 pm
Installed Flowcode on my laptop running windows vista home premium and have several faults.
on simulation a message stack not available.
On compiling to Hex I get the following which seams all string errors. that was not there on my home desktop which runs vista ultimate 64 bit.
File name: C:\Battery Processor\Batprocess02.c
Generated by: Flowcode v3.4.7.48
Date: Saturday, December 27, 2008 14:51:16
Licence: Professional
Registered to: jOHN fINLAYSON
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic18.flowcode.exe -v -t PIC18F252 "Batprocess02.c"
BoostC Optimizing C Compiler Version 6.70 (for PIC18 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC18 max code size:Unlimited, max RAM banks:Unlimited
Batprocess02.c
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "C:\Battery Processor\Batprocess02.c" -i "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC18F252 -la -c2 -o Batprocess02.pp -v -d _BOOSTC -d _PIC18
Batprocess02.c success
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostlink.pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V3\Boostc\lib" libc.pic18.lib "Batprocess02.obj" -t PIC18F252 -d "C:\Battery Processor" -p "Batprocess02"
BoostLink Optimizing Linker Version 6.70
Error: Unresolved external function:'FCI_TOSTRING(signed int,unsigned char*,unsigned char)'
Error: Unresolved external function:'FCI_CONCATENATE(unsigned char*,unsigned char,unsigned char*,unsigned char,unsigned char*,unsigned char)'
Error: Unresolved external function:'FCI_GETLENGTH(unsigned char*,unsigned char)'
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
FINISHED
The list is longer but cut down to save space. I am presently away working on a ship and cannot down load exe files and to reinstall would require an email with ziped file that is less than 500Kb. Not due back to sivilisation until end of January.
Hopefully you will recocnise this error.
Batprocess02.c
success
Return code = 0
failure
Return code = -2
FINISHED
