18F4458 And FlowCode V3
Posted: Tue Jan 06, 2009 6:42 am
by Cris
Hi, This is my first post and I have an easy question. Has anyone been able to work the 18F4458 into FlowCode V3? I have this chip and would like to use it in my FlowCode Pro V3. I searched the forum but found nothing on this chip. Also does someone know why FlowCode does not seem to know that my 16F677 has a USART function? when I try to compile a file that uses USART it fails saying the chip does not have a USART function. hope you can help Thanks
Cris :P
Re: 18F4458 And FlowCode V3
Posted: Tue Jan 06, 2009 9:41 am
by Sean
Hello Cris,
It should be possible to create a .fcd file for the PIC18F4458, probably based on on the .fcd file of an existing, similar device. I will post the file, or conversion information, when I have checked the data sheets.
The PIC16F677 does not have a USART. Some of the larger devices in the family range (16F690 etc.) do include a USART. But the 16F677 only contains an SSP to allow support of the I2C and SPI busses.
Posted: Tue Jan 06, 2009 10:27 am
by Sean
Unfortunately it would appear that the PIC18F4458 can not be included in the list of supported devices for the current version of Flowcode.
The closest supported device is probably the PIC18F4455.
Posted: Tue Jan 06, 2009 11:02 am
by Steve
Support for the '4458 will be available in Flowcode V4.
Posted: Tue Jan 06, 2009 6:40 pm
by Cris
Yes your right, I should have paid more attention to the pin out on the 16F677 data sheet. I was looking at the USART block diagram, which refers to the pins as TX/CK and RX/DT like my 877A. I think that’s where I went astray, the pin out for the 677 clearly shows only SDI/SDA and SCL/SCK. I will give the 4458 a go using the 4455 .fcd template as a base. Thanks for the quick and accurate reply. Looking forword to FlowCode V4.
Cris :oops:
Posted: Wed Oct 28, 2009 9:06 pm
by Cris
Hello all, Well FlowCode 4 is out but I do not see an FCD for the 18F4458 as Steave said and I have been keeping an eye on this post but have not seen any further reply from Sean on an FCD. If any one has one for the 18F4458 I would sure like to see it if posible. Thanks for the help
Cris :P
Posted: Thu Oct 29, 2009 12:46 pm
Here is a 18F4458 FCD file for V4 of Flowcode. This should be included in the next release of Flowcode which will be v4.2.
Posted: Sun Nov 01, 2009 6:27 pm
by Cris
Ben,
Thanks for the FCD file. I have changed it a little so it seems to work with FlowCode V3 but when I tried to test it the operation fails when trying to compile because PPPv3 does not seem to have the 18F4458 in it’s config data files. I went to the web site but could not locate an update for PPPv3, is one available that has support for the 18F4458 with FlowCode v3? I have attached my changed version of the FCD file for your viewing in case you think the problem is with my changes. Hope you can help, Thanks again
Cris
:roll:
Posted: Mon Nov 02, 2009 9:24 am
Hello Cris
There currently is not a version of PPP that will support this device.
However if you look in the main Flowcode help file in the "Compiling flowcharts to devices" section you will find the "Configuring the chip" topic. In here it shows you how to define your own manual configuration settings. To do this you will need to refer to the device datasheet to find the correct configuration values for your setup.
