Could not ID the onboard chip!!!
Posted: Thu Jul 09, 2009 10:41 am
Hello everyone!!!!
I am new to flowcode programming..I m using 16F877A and 16F88 microcontroller.
To do a simple program of lighting of LED's i have Created a new flowchart, specifying the microcontroller that I wish to target. I have Run the simulation to check that the application behaves as expected or not and it is working fine. Now ehenever i m Transferring the application to the microcontroller by compiling the flowchart to C, then to assembler code and finally to object code , it is giving the following error- "Could not ID the onboard chip-assuming it is one specified in the configuration screen".
Now in the troubleshooting guide of dis prob there are sum steps given to erase the microcontroller, but whenever i m following those steps , it again gives the same error message.
can ne1 plss tell me where i m going wrong and wat could be the possible reason and how it could be troubleshooted??
Plss help me as i m new to this programming..THank you very much in avance!!!
