PROBLEM WITH FLOW CODE 4
Posted: Thu Jul 30, 2009 12:34 am
Hello BenJ,
I have to put this on FCV3 basket because there was no basket for FCV4 currently so excuseme for that.
I was creating my first programs on FC V4 but I have got some problems that you probably will let know the reason.
1.I uninstalled the FC V3 and then Installed the version 4 but despite when I wnated to save the program a window emerged telling that the access was denied because I must be the administrator Why?? if I useed the same path I used to install FCV3. So I had run run the program as administrator.
2.Once I created the program I tried to simulate it but the switches does not run well. The ODS turns on and off well but the LONS is stucked.But when run the program step by step bought switches work fine and the behavior of the program is as expected. I compared this routine with one I created with FCV3 and the last one funtioned well.
I have attached the bought routines and please tell me what I am doing wrong. The routines are very simple.
