display connection
Posted: Wed Nov 11, 2009 8:18 pm
by franky
hi at all!,
i have a problem, i'm using WH1604A 16x4 character, i've the pins assigment in datasheet, but in flowcode into the connection proprieties there are only data1 to data4, plus RS and Enable...
is it possible to use this display?
thanks!
best regards
Re: display connection
Posted: Thu Nov 12, 2009 9:01 am
Hello Franky
Have a look at the schematic at the end of this datasheet.
http://www.matrixmultimedia.com/datashe ... 5-30-3.pdf
It will show you the pin connections that are required to get your display up and running.
Posted: Thu Nov 12, 2009 11:26 am
by franky
Hi Benj,
i have tryed and work correctly!... thank you so much!
regards!
