error boostc~2
Wetzels
error boostc~2
Post by Wetzels »
i use flowcode v4 with windows 7.
evrytime i click on the compile the program and sent it to the processor i get an error message with
boostc~2 doesn't work anymore and must close.
also in the message: can't translate c code.
Re: error boostc~2
Is it possible to copy paste the text from the compiler error message or to take a print screen so we can better see whats going on.
Does this happen when you try to compile any programs or is the problem limited to specific programs?
If you go into the Chip -> Compiler options window and then click restore defaults then this may fix things for you.
Wetzels
Re: error boostc~2
Post by Wetzels »
this is the error i get, its only in dutsch.
its when i try to compile the program to hex or into the chip
restore default doesn,t work.
picture of the error
error boostc 1.jpg (47.39 KiB) Viewed 2493 times
picture error 2
picture error 2
error boostc 2.jpg (77.95 KiB) Viewed 2493 times
Re: error boostc~2
Please can you try this FAQ topic and let me now how you get on. I know this fixes the problem in XP and Vista but not sure about windows 7.
http://www.matrixmultimedia.com/support ... .php?t=518
