Hello, just would like to confirm that all of the sensors are compatible with the white (analog & digital) sensor inputs on the ver. 3 dev board?
Thanks, Rob
sensor connections
keypad macro
Sorry I sometimes I don't see the "new topic" button.
Anyway, I cannot figure out why this program will not compile.
Please help. (see attached) It's a very short and simple program to display a number from the keypad to the lcd display.
It seems there's an issue with the keypad macro, it compiles fine until I add the keypad macro.
Thanks,Rob
This is the message I get.
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F877A "doorbell3.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Standard License for 1 node(s)
Limitations: PIC12,PIC16 max code size:4096 words, max RAM banks:Unlimited, Non commercial use only
doorbell3.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\pp.exe "C:\Documents and Settings\Rob\Desktop\robs flowfiles\doorbell3.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\include -d _PIC16F877A -la -c2 -o "C:\Documents and Settings\Rob\Desktop\robs flowfiles\doorbell3.pp" -v -d _BOOSTC -d _PIC16
C:\Documents and Settings\Rob\Desktop\robs flowfiles\doorbell3.c(232): error: missing semicolon
C:\Documents and Settings\Rob\Desktop\robs flowfiles\doorbell3.c(177): error: failure
failure
Return code = 1
FINISHED
Thanks,Rob
doorbell3.c
failure
Return code = 1
FINISHED
- doorbell3.fcf
- (7.5 KiB) Downloaded 328 times
Re: sensor connections
The keypad component is disconnected and this is causing problems when compiling the C code. Select the keypad and then click the component connections button to assign a port and pins.
wow! that's embarrassing..
Do the columns and rows need to be connected individually?
In other words, when I connect the columns the rows remain dis-connected until I connect them to the same port.
Rob
Rob
Hello Rob,
The columns and rows have to be connected seperatley as we now allow for them to be connected to different ports. You can however connect both to the same port and that will work fine.
