Does anybody know how to count the PWM pulses generated by the ccp module (in Flowcode 4.2) ? I want for example to generate 100 pulses from a certain frequency.
Thank you,
Sorin
PWM count
Re: PWM count
Hello Sorin,
You should be able to use a delay to do this. eg a count of 100 with a PWM running at 100 hz would take 1 second, at 1000hz would take 100ms etc.
Re: PWM count
Indeed is a great idea. I turn on pwm then I put a desired delay and then I disable pwm and so I will have a defined number of pulses. Thank you very much Benj!
Best regards,
Sorin
Best regards,
Sorin
