audio trans.
arush
audio trans.
Post by arush »
(a) i just need to ask you if it is beneficial for speech signal transmission through zigbee purpose and if it is, than how and how i am gona start with it.
(b) what would you suggest me, if i use an anti aliasing filter in between a microphone and the zigbee coordinator side(the pic board ie. transmitter board), on the port-e.
(c) which pins of port-e can i use to connect for those three analog inputs.
Re: audio trans.
a) The analyser is purely to allow you to see the messages and to inject messages if you require.
b) sounds good.
c) Depends on the chip your using. Normally port E only has pins 0 - 3.
arush
Re: audio trans.
Post by arush »
thanks
