pwm 6722
Posted: Fri Jul 09, 2010 9:15 am
by saschech@gmx.de
Hello Benj
The pwm not work on hardware if i set to pin re7
Please help
Regards Wolfgang
Re: pwm 6722
Posted: Fri Jul 09, 2010 11:07 am
Hi Wolfgang,
To get the alternative PWM pin working you need to change the settings in 2 places.
1) The configuration settings - This you have already done.
2) The PWM properties - This needs doing for the Port and Pin settings to be updated in the C code.
Hopefully this should allow the alternative PWM channel to work.
Re: pwm 6722
Posted: Fri Jul 09, 2010 11:51 am
by saschech@gmx.de
Hello Benj
Change from ccp2 to re7 in The PWM properties work ok.
Thank you
Regards Wolfgang
