read pulse burst
Posted: Tue Aug 24, 2010 6:30 pm
by Rotac
Hello everybody,
has sombody an examble in flowcode or experiance to "read" (via input) a pulse burst.
I want to know number of pulse, pulse frequence (high and low time) etc.
Kindly regards
Rob
Re: read pulse burst
Posted: Tue Aug 24, 2010 8:21 pm
Hi Rob,
There is a frequency counter example as port of the Flowcode example files. Maybe you could add your extra functionality to this.
Posted: Wed Aug 25, 2010 5:51 pm
by Rotac
Hello Benj,
Thank you for your quick responce. I'm missing some posibilitys, for e.g. measure the puls lenght, do yo have a suggestion how to do this?
In simulate mode you can't generate a pulse on the input, perhaps in a new Version of Flowcode to build in a puls generator for simulation
Kindly regards
Rob
Posted: Thu Aug 26, 2010 8:41 am
Rotac wrote: I'm missing some posibilitys, for e.g. measure the puls lenght, do yo have a suggestion how to do this?
Hello Rotac.
sean posted an example flowchart on calculating pulse lengths here:
http://79.99.43.2/mmforums/viewtopic.ph ... 65&p=16135
(About 11th post down)
Unfortunaly it will only work with flowcode V4 and not V3
What version are you running?
Is it V4 demo since you have not posted in V3 or V4 section?
Posted: Thu Aug 26, 2010 12:03 pm
Just had a thought from seeing a post about RC5 protocol.
That would would use a pulse width timing routine, so infrared signal can be decoded.
So also look at:
http://www.matrixmultimedia.com/mmforum ... =26&t=7246
Posted: Thu Aug 26, 2010 3:13 pm
by Rotac
Hello medelec35,
thanks for your information. I will study these posibilitys.
Kindly regards
rob
