C Box declarations for "long" or "short"
Huib Koppers
Post by Huib Koppers »
Is het possible to make new variable declarations for other formats then standard supported by FC v4 for example;
"long int" 32bits
"short int" 16bits
If yes how can I do this in the C-Box ?
Huib
Re: C Box declarations for "long" or "short"
Huib Koppers
Hello medelec,
BoostC does not make part of the ARM and AVR directory.
It could be helpfull if there is a document for FCv4 to ARM and AVR how to implement non standard variables and functions in C code into the C-Box so that compiling it without errors for users who are not so advanced and familiar with C Code.
Also there will be not unnessesary questions made on this forum so that you all can spent more time on more important questions for advanced users.
Is that an option ?
regards Huib
Hello Huib,
The following should work for almost any embedded C compiler though don't quote me on that one :P
32-bit variables
signed long x;
unsigned long x;
16-bit variables
signed int x;
unsigned int x;
short x;
NB: shorts are normally exactly the same as "signed int" variables.
8-bit variables
signed char x;
unsigned char x;
char x;
NB: chars are normally exactly the same as "unsigned char" variables.
Signed variables can go negative and unsigned variables are positive only.
16-bit Unsigned is 2 to the power 16 so 0 to 65535
16-bit signed is 2 to the power 16 with 0 being in the middle of the range so -32768 to 32767
Covering all the basics of C in a single document would be fairly tricky and time consuming and is not likely to generate any sales so its probably not worth us doing this unless there is a big demand for such a thing from our customers.
When working with long variables it is normally worthwhile doing a type cast or the compiler will normally default to a 16-bit calculation. To type cast you would do something like this.
unsigned long var1;
var1 = (unsigned long) 158 * 25;
Basically just putting the variable type in brackets after the equals sign but before the calc.
Here is how it is used in the FAT routines when handling 32-bit variables.
root_size = Read_Byte_From_Buffer(0x24);	//Size of root directory x 32 byte file/directory entries
root_size = root_size | ( Read_Byte_From_Buffer(0x25) << 8);
root_size = root_size | ((long)  Read_Byte_From_Buffer(0x26) << 16);
root_size = root_size | ((long)  Read_Byte_From_Buffer(0x27) << 24);
Huib Koppers
Hello Benj,
Thanks for your reply,
This gives me a better understanding how C things about variables and declarations can be implemented in FlowCode.
I'm just a hobbyist and held MM not responsible for any comment, but sometimes it can be that i have some questions which are very importand for me.
Fortunately I'm not so familiar with C and only want to learn about this and how it is done in C by syntax writing.
So the examples you have mentioned are a big help for me.
Thanks a lot
Huib
