Connection Problems with EB024
Posted: Mon Oct 18, 2010 8:45 am
by PortUniChris
Hi all,
Having a problem with my EB024 Bluetooth board. All connections are fine, and yet the device is undiscoverable. Anybody know of a fix for this? Also, if it is broken, I suspect only the Bluetooth module would be damaged. It's much cheaper to buy the module than the whole board again, so does anyone know if this would be suitable?
http://www.farnell.com/datasheets/8179.pdf
http://uk.farnell.com/ezurio/trblu24-00 ... dp/1491599
It's the same product, first one is the data sheet!
Thanks guys!
Chris
Re: Connection Problems with EB024
Posted: Tue Oct 19, 2010 2:19 pm
Hello Chris,
I have had a look at the module you suggested and it is the incorrect pin out for the EB024 E-block.
This module would be a replacement for the module on the board.
http://uk.farnell.com/ezurio/btm402/mod ... dp/1491602
Posted: Tue Oct 19, 2010 2:35 pm
by PortUniChris
Excellent. Thank You!
Any ideas why it could've died? Power still runs through it, just isn't discoverable so I assumed it was the module :roll:
Posted: Wed Oct 20, 2010 4:16 pm
Could be that the discoverability has been disabled? Have you tried loading a program that sets the module up as discoverable again? Example 1 available here should do just that.
http://www.matrixmultimedia.com/Learnin ... /EB980.zip
Posted: Wed Oct 20, 2010 4:48 pm
by PortUniChris
Thanks, I'll give that a try. I didn't do anything that would do that I don't think, but it's worth a shot.
Chris
Posted: Thu Oct 21, 2010 4:44 pm
by PortUniChris
One more question, any ideas what the standard Baud Rate is of the EB024? I'm reading 100kBps in the data sheet, which would imply 800,000 bits per second. Is this correct, as I can't find any other mention of Baud Rate in the data sheet?
Posted: Thu Oct 21, 2010 4:48 pm
The standard baud for the module is 9600 bits per second I think.
Edit: Yes 9600bps confirmed :)
Posted: Tue Nov 16, 2010 1:07 pm
by PortUniChris
I can't open the example which you gave me to make the device discoverable again, as I'm using ATMEL AVR.
Please can I have a compatible file?
