PROBLEM COMPILING WITH SOURCE BOOST V7
miguelmauricior
Flowcode V4 User
Post by miguelmauricior »
Hi I have updated from Source boost V6.95 to V7 and the original paht for the compiler in the Flow code commands was:
C:\Program Files\SourceBoost\Lib" libc.pic16.lib rand.pic16.lib float.pic16.lib "%f.obj" -t PIC%p -d "%d" -p "%f"
This generated this massage:
___________________________________________________________________________________________
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC12F629 "LIGHTONALARM.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
LIGHTONALARM.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe "C:\Program Files\Matrix Multimedia\FlowCode projects\LIGHTONALARM.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC12F629 -la -c2 -o "C:\Program Files\Matrix Multimedia\FlowCode projects\LIGHTONALARM.pp" -v -d _BOOSTC -d _PIC16
LIGHTONALARM.c success
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostlink.pic.exe -ld "C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\lib" libc.pic16.lib flowcode.pic16.lib rand.pic16.lib float.pic16.lib "LIGHTONALARM.obj" -t PIC12F629 -d "C:\Program Files\Matrix Multimedia\FlowCode projects" -p "LIGHTONALARM"
BoostLink Optimizing Linker Version 6.95
Warning unreferenced functions removed:
FCI_FLOAT_TO_STRING in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_NUMBER_TO_HEX in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_INT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
FCI_STRING_TO_FLOAT in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_msDelay in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_S in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Wdt_Delay_Ms in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
isinf in: C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h
Building CASM file
Memory Usage Report
RAM available:64 bytes, used:45 bytes (70.4%), free:19 bytes (29.6%),
Heap size:19 bytes, Heap max single alloc:18 bytes
ROM available:1024 words, used:339 words (33.2%), free:685 words (66.8%)
success
Return code = 0
Launching the programmer...
C:\Program Files\Matrix Multimedia\Flowcode V4\tools\PICkit2\pk2cmd.exe -PPIC12F629 -FLIGHTONALARM.hex -M -A5 -T -R -BC:\Program Files\Matrix Multimedia\Flowcode V4\tools\PICkit2\
No PICkit 2 found.
Return code = 10
Flowcode no pudo transferir el diagrama de flujo al microcontrolador. Verifique que las opciones del programa ensamblador y las conecciones físicas sean correctas.
FINISHED
Then I updated the compiler options by this path(C:\Program Files\SourceBoost\boostc++_pic16.exe) I got this:
C:\Program Files\SourceBoost\boostc++_pic16.exe -v -t PIC12F629 "LIGHTONALARM.c"
BoostC++ Optimizing C++ Compiler Version 7.00 (for PIC16 architecture)
Copyright(C) 2004-2010 Pavel Baranov
Copyright(C) 2004-2010 David Hobday
Licensed to MMRZ under Single user Full License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited, Non commercial use only
LIGHTONALARM.c
Starting preprocessor: C:\PROGRA~1\SOURCE~1\pp.exe "C:\Program Files\Matrix Multimedia\FlowCode projects\LIGHTONALARM.c" -i C:\PROGRA~1\SOURCE~1\include -d _PIC12F629 -la -c2 -o "C:\Program Files\Matrix Multimedia\FlowCode projects\LIGHTONALARM.pp" -v -d _BOOSTC -d _BOOSTCPP -d _PIC16 -d _CHAR_INDEX
success
Return code = 0
Error: .obj or .lib file Incompatible version! (file uses V112, linker requires V109 to V111)
Error: Failed to process:LIGHTONALARM.obj
failure
Return code = -2
Flowcode no pudo ensamblar el archivo ASM debido a los siguientes errores:
FINISHED
______________________________________________________________________________________________________________________________________
Can you tell me what is missing? How is the correct way to update the linker? and what other thinks must be updated?
THANKS.......
MMRZ
saschech@gmx.de
Has thanked: 1 time
Been thanked: 26 times
Re: PROBLEM COMPILING WITH SOURCE BOOST V7
Post by saschech@gmx.de »
I think all users have these message and all must wait for a update
Regards Wolfgang
Yes Wolfgang is correct here. We have special linkers made for Flowcode which are not compatible with the default BoostC installation. Therefore the version of Sourceboost is directly tied to the release version of Flowcode.
Can you continue to use Flowcode with the original path and parameters for the BoostC compiler and linker? Or does the installation of the latest BoostC cause problems with the version used by Flowcode?
saschech@gmx.de
Has thanked: 1 time
Hello Steve
I can use Flowcode with the original path and parameters.
Regards Wolfgang
