Steve wrote:I think your best option is to re-write the TASM code as MPASM code.
I have found some free software which I tried on windows 7. It converts TASM to MPASM ,so no editing to do.
It's called Asmtidy and you can download from.
http://www.unusualelectronics.co.uk/pro ... smtidy.php
As an example I loaded:
#DEFINE PAGE0 BCF $03,5
#DEFINE PAGE1 BSF $03,5
List P = PIC16F877, R=DEC;
__CONFIG h'3F31'
INDF: .EQU $00 ;page 0, 1, 2, 3
OPTION: .EQU $01 ;page 1, 3
PCL: .EQU $02 ;page 0, 1, 2, 3
STATUS: .EQU $03 ;page 0, 1, 2, 3
FSR: .EQU $04 ;page 0, 1, 2, 3
PORTA: .EQU $05 ;page 0
TRISA: .EQU $05 ;page 1
PORTB: .EQU $06 ;page 0, 2
TRISB: .EQU $06 ;page 1, 3
PORTC: .EQU $07 ;page 0
TRISC: .EQU $07 ;page 1
PORTD: .EQU $08 ;page 0
TRISD: .EQU $08 ;page 1
PORTE: .EQU $09 ;page 0
TRISE: .EQU $09 ;page 1
PCLATH: .EQU $0A ;page 0, 1, 2, 3
INTCON: .EQU $0B ;page 0, 1, 2, 3
EEDATA: .EQU $0C ;page 2
EECON1: .EQU $0C ;page 3
PIR2: .EQU $0D ;page 0
EEADR: .EQU $0D ;page 2
EECON2: .EQU $0D ;page 3
ADCON1: .EQU $1F ;page 1
SLOWIT: .EQU $20 ; pause counter
CLKCNT: .EQU $21
CLKSEC: .EQU $22
CLKMIN: .EQU $23
CLKHRS: .EQU $24
LOOP: .EQU $25
LOOPA: .EQU $26
RSLINE: .EQU $27
STORE: .EQU $28
STORE1: .EQU $29
STORE2: .EQU $2A
STORE3: .EQU $2B
ZONESVAL: .EQU $2C ; current val of zones status
ALARMSTATUS: .EQU $2D ; controls the following:
; bit 0 buzzer
; bit 1 strobe
; bit 2 bell
; bit 3 -
; bit 4 Panic flag
; bit 5 passive entry zone (just turns on buzzer when entered)
; bit 6 power interrupt flag
; bit 7 alarm on flag
SWITCH1: .EQU $2E ; multiplex val for rows
SWVAL: .EQU $2F ; input val from RB0-RB3
COL: .EQU $30 ; column counter (inc in decimal)
ROW: .EQU $31 ; row counter (inc as matrix val)
ROWNUM: .EQU $32 ; row counter (inc in decimal)
ALARMZONE: .EQU $33 ; holds status of which zone triggered
KEYPRESS: .EQU $34 ; value of key pressed keypad1
PIN0: .EQU $35 ; 1st pin number val FIRST KEYPAD
PIN1: .EQU $36 ; 2nd pin number val
PIN2: .EQU $37 ; 3rd pin number val
PIN3: .EQU $38 ; 4th pin number val
EXITTIME: .EQU $39 ; entry/exit delay
EXITZONE: .EQU $3A ; entry/exit zone
INCLZONE: .EQU $3B ; zones to be included in monitoring
BELLTIME .EQU $3C ; bell on time value in BCD mins
FLASH: .EQU $3D ; flag for flashing buzzer LED when zone incorrectly open during alarm setting
ZONENORMAL: .EQU $3E ; normal zone logic
ENGINEERSET: .EQU $3F ; flag to indicate if ENGINEER has been called
PREVALARMZONE .EQU $40 ; previous alarm condition register
ENTRYDELAY: .EQU $41 ; counter for entry/exit delay
PIN4: .EQU $42 ; 1st pin number val FOR 2ND KEYPAD
PIN5: .EQU $43 ; 2nd pin number val
PIN6: .EQU $44 ; 3rd pin number val
PIN7: .EQU $45 ; 4th pin number val
KEYPRESS2: .EQU $46 ; value of key pressed keypad2
ENTRYTIME2: .EQU $47 ; entry time for keypad2
ENTRYDELAY2: .EQU $48 ; counter for keypad2 entry delay
CLKCNT2: .EQU $49
STORED .EQU $4A ; temp store for keypad2
COUNT0 .EQU 0x50 ;lsb
COUNT1 .EQU 0x51
COUNT2 .EQU 0x52 ;msb
DIGIT1 .EQU 0x53 ;lsd
DIGIT2 .EQU 0x54
BITCNT .EQU 0x5B
DIGCNT .EQU 0x5C
STOREX: .EQU $60
STOREY: .EQU $61
; locations up to $7F are available
; Bit Definitions
W: .EQU 0
F: .EQU 1
C: .EQU 0
DC: .EQU 1
Z: .EQU 2
RP0: .EQU 5 ;STATUS reg
RP1: .EQU 6 ;STATUS reg
GIE: .EQU 7 ;INTCON reg
RD: .EQU 0 ;EECON1 reg eeprom read enable flag
WR: .EQU 1 ;EECON1 reg eeprom write initiate flag
WREN: .EQU 2 ;EECON1 reg eeprom write enable flag
EEPGD: .EQU 7 ;EECON1 reg
EEIF: .EQU 4 ;PIR2 reg
BUZZER: .EQU 0
STROBE: .EQU 1
BELL: .EQU 2
PANIC: .EQU 4
RBIF: .EQU 0
;............. DATA EEPROM USE
; 0-3 PIN CODE
; 4 ZONES EXCLUDED
; 5 ENTRY/EXIT ZONE
; 6 ENTRY/EXIT DELAY
; 7 ZONES INTRUDED (AlarmZone)
; 8 ALARM ON/OFF & BELL, BUZZER, STROBE STATUS (AlarmStatus)
; 9 BELL ON TIME (MAX 15 MINS)
; 10 NORMAL ZONE STATUS
; 11-14 2ND PIN CODE
; 15 ENTRY DELAY VIA KEYPAD2
.ORG $0004 ;Interrupt vector address
GOTO GIEOFF ;Jump to interrupt routine on interrupt
.ORG $0005 ;Start of program memory
GIEOFF: BCF INTCON,GIE ;turn off global interrupts
BTFSC INTCON,GIE
goto GIEOFF
goto START
TABLCD: addwf PCL,F ;LCD initialisation table
retlw %00110011 ;initialise lcd - first byte
retlw %00110011 ;2nd byte (repeat of first)
retlw %00110010 ;set for 4-bit operation
retlw %00101100 ;set for 2 lines
retlw %00000110 ;set entry mode to increment each address
retlw %00001100 ;set display on, cursor off, blink off
retlw %00000001 ;clear display
retlw %00000010 ;return home, cursor & RAM to zero
;end inititalisation table
ALLOFF: addwf PCL,F
retlw 'A'
retlw 'L'
retlw 'L'
retlw ' '
retlw 'O'
retlw 'F'
retlw 'F'
retlw ' '
MESSAGON: addwf PCL,F
retlw 'A'
retlw 'L'
retlw 'A'
retlw 'R'
retlw 'M'
retlw ' '
retlw 'O'
retlw 'N'
retlw ' '
MESSAG2: addwf PCL,F
retlw ' '
retlw ' '
retlw 'E'
retlw 'N'
retlw 'T'
retlw 'R'
retlw 'Y'
retlw ' '
CHKVAL: addwf PCL,F
retlw %01011001 ;59 secs max
retlw %01011001 ;59 mins max
retlw %00100011 ;23 hours max
VALUE: ADDWF PCL,F ;lookup table for key allocation
retlw '1'
retlw '2'
retlw '3'
retlw 'A'
retlw '4'
retlw '5'
retlw '6'
retlw 'B'
retlw '7'
retlw '8'
retlw '9'
retlw 'C'
retlw '-'
retlw '0'
retlw 'E'
retlw 'D'
BITVALUE: ADDWF PCL,F ;lookup table for decimal to bit conversion
retlw 0
retlw 1
retlw 2
retlw 4
retlw 8
retlw 16
retlw 32
retlw 64
retlw 128
PINCODE: ADDWF PCL,F ; change pin code message
retlw 'C'
retlw 'H'
retlw 'A'
retlw 'N'
retlw 'G'
retlw 'E'
retlw ' '
retlw 'P'
retlw 'I'
retlw 'N'
retlw ' '
retlw 'C'
retlw 'O'
retlw 'D'
retlw 'E'
retlw ' '
PIN2MSG: ADDWF PCL,F ; change 2ND pin code message
retlw 'S'
retlw 'E'
retlw 'T'
retlw ' '
retlw '2'
retlw 'N'
retlw 'D'
retlw ' '
retlw 'P'
retlw 'I'
retlw 'N'
retlw ' '
retlw 'C'
retlw 'O'
retlw 'D'
retlw 'E'
ENTRYTIME: ADDWF PCL,F ; change ENTRY/EXIT time message
retlw 'S'
retlw 'E'
retlw 'T'
retlw ' '
retlw 'I'
retlw 'N'
retlw '/'
retlw 'O'
retlw 'U'
retlw 'T'
retlw ' '
retlw 'T'
retlw 'I'
retlw 'M'
retlw 'E'
retlw ' '
BELLTIMEMSG: ADDWF PCL,F ; change ENTRY/EXIT time message
retlw 'S'
retlw 'E'
retlw 'T'
retlw ' '
retlw 'B'
retlw 'E'
retlw 'L'
retlw 'L'
retlw ' '
retlw 'O'
retlw 'N'
retlw ' '
retlw 'T'
retlw 'I'
retlw 'M'
retlw 'E'
ENTRYZONE: ADDWF PCL,F ; set ENTRY/EXIT zone message
retlw 'S'
retlw 'E'
retlw 'T'
retlw ' '
retlw 'I'
retlw 'N'
retlw '/'
retlw 'O'
retlw 'U'
retlw 'T'
retlw ' '
retlw 'Z'
retlw 'O'
retlw 'N'
retlw 'E'
retlw ' '
MODEMSG: ADDWF PCL,F ; mode message
retlw 'S'
retlw 'E'
retlw 'L'
retlw 'E'
retlw 'C'
retlw 'T'
retlw ' '
retlw 'M'
retlw 'O'
retlw 'D'
retlw 'E'
retlw ' '
retlw ' '
retlw ' '
retlw ' '
retlw ' '
WATCHMSG: ADDWF PCL,F ; zones to be watched message
retlw 'S'
retlw 'E'
retlw 'T'
retlw ' '
retlw 'W'
retlw 'A'
retlw 'T'
retlw 'C'
retlw 'H'
retlw ' '
retlw 'Z'
retlw 'O'
retlw 'N'
retlw 'E'
retlw 'S'
retlw ' '
OPENZONE: ADDWF PCL,F ; zones incorrectly open when alarm is being set
retlw 'C'
retlw 'H'
retlw 'E'
retlw 'C'
retlw 'K'
retlw ' '
retlw 'O'
retlw 'P'
retlw 'E'
retlw 'N'
retlw ' '
retlw 'Z'
retlw 'O'
retlw 'N'
retlw 'E'
retlw 'S'
ZONELOGIC: ADDWF PCL,F ; assess zone logic message (i.e normally open or normally closed)
retlw 'A'
retlw 'U'
retlw 'T'
retlw 'O'
retlw ' '
retlw 'Z'
retlw 'O'
retlw 'N'
retlw 'E'
retlw ' '
retlw 'A'
retlw 'S'
retlw 'S'
retlw 'E'
retlw 'S'
retlw 'S'
SHOWLOGIC: ADDWF PCL,F ; assess zone logic message (i.e normally open or normally closed)
retlw 'N'
retlw 'O'
retlw 'R'
retlw 'M'
retlw ' '
retlw 'Z'
retlw 'O'
retlw 'N'
retlw 'E'
retlw ' '
retlw 'L'
retlw 'O'
retlw 'G'
retlw 'I'
retlw 'C'
retlw ' '
PASSIVEMSG: ADDWF PCL,F ; passive alarm message
retlw 'M'
retlw 'O'
retlw 'N'
retlw 'I'
retlw 'T'
retlw 'O'
retlw 'R'
retlw ' '
START: bcf STATUS,RP0
bcf STATUS,RP1
clrf PORTA
clrf PORTB
clrf PORTC
clrf PORTD
clrf PORTE
PAGE1
movlw %11011111 ;RB0-RB4, RB6-RB7 as input, RB5 as output
movwf TRISB
movlw %00001111 ;RC0-RC3 as input, RC4-RC7 as output
movwf TRISC
movlw 255
movwf TRISD ;PORTD as input
clrf TRISE ;PORTE as output
movlw %00000111 ;PORT A/E as digital
movwf ADCON1 ;
movlw %11000000 ;RA0-RA5 as outputs
movwf TRISA
movlw %00000110 ;timer 1:128 (1/25th sec)
movwf OPTION
PAGE0
clrf INTCON
call PAUSIT ;1/5 sec delay
LCDSET: clrf LOOP ;clr LCD set-up loop
clrf RSLINE ;clear RS line for instruction send
LCDST2: movf LOOP,W ;get table address
call TABLCD ;get set-up instruction
call LCDOUT ;perform it
incf LOOP,F ;inc loop
btfss LOOP,3 ;has last LCD set-up instruction now been done?
goto LCDST2 ;no
clrf ENGINEERSET
bsf ALARMSTATUS,6 ; set Power interruption flag
call KEYPAD1 ; is ENGINEER code to be entered following power-up
movf KEYPRESS,W ; with key 'D' pressed?
xorlw 'D'
btfss STATUS,Z
goto SETCLK ; no
clrf ALARMZONE
clrf ALARMSTATUS
bsf ENGINEERSET,0
bcf ALARMSTATUS,6 ; clear Power interruption flag
movlw %10000001 ; default set INCLZONE for zones 1 & 8
movwf STORE1
movlw 4
call SETPRM
movlw %00000001 ; default set entry/exit zone
movwf STORE1
movlw 5
call SETPRM
movlw 30 ; default set EXITTIME to 30 secs in binary
movwf STORE1
movlw 6
call SETPRM
clrf STORE1 ; default clear INTRUDED status
movlw 7
call SETPRM
clrf PORTE
clrf STORE1 ; default clear ALARMSTATUS (bell etc)
bcf STORE1,BELL
movlw 8
call SETPRM
movlw %00010101 ; default set bell switch-off time to 15 mins in BCD
movwf STORE1
movlw 9
call SETPRM
movlw %00000000 ; default set for "normal" zone status - all open
movwf STORE1
movlw 10
call SETPRM
movlw 30 ; default set ENTRYTIME to 30 secs in binary for keypad2
movwf STORE1
movlw 15
call SETPRM
call ENGINEER ; yes, set ENGINEER entry code and reset all defaults
SETCLK: clrf CLKSEC ;clear seconds counter
clrf CLKMIN ;clear minutes counter
clrf CLKHRS ;clear hours counter
clrf PREVALARMZONE
clrf ENTRYDELAY
clrf ENTRYDELAY2
movlw 25 ;initial basic CLKCNT val for secs timing
movwf CLKCNT
movlw 0 ; RECALL PIN CODE
call PRMGET
movwf PIN0
movlw 1
call PRMGET
movwf PIN1
movlw 2
call PRMGET
movwf PIN2
movlw 3
call PRMGET
movwf PIN3
movlw 4 ; RECALL INCLUDED/EXCLUDED ZONES
call PRMGET
movwf INCLZONE
bsf INCLZONE,7 ; ensure bit 7 (1st PANIC zone) is always on
movlw 5 ; RECALL ENTRY/EXIT ZONE
call PRMGET
movwf EXITZONE
movlw 6 ; RECALL ENTRY/EXIT TIME
call PRMGET
movwf EXITTIME
movlw 7 ; RECALL ALARMZONE STATUS
call PRMGET
movwf ALARMZONE
movlw 8 ; RECALL ALARMSTATUS STATUS
call PRMGET
movwf ALARMSTATUS ; and activate buzzer/strobe if needed (but not bell)
andlw %00000011
movwf PORTE
movlw 9 ; RECALL BELL ON TIME
call PRMGET
movwf BELLTIME
movlw 10 ; RECALL "NORMAL ZONE STATUS
call PRMGET
movwf ZONENORMAL
movlw 11 ; RECALL PIN CODE 2
call PRMGET
movwf PIN4
movlw 12
call PRMGET
movwf PIN5
movlw 13
call PRMGET
movwf PIN6
movlw 14
call PRMGET
movwf PIN7
movlw 15 ; RECALL ENTRY TIME FOR KEYPAD2
call PRMGET
movwf ENTRYTIME2
btfss ALARMSTATUS,7 ; is alarm on?
goto ITSOFF
call CHECKZONE2
goto MAIN
ITSOFF: call ALARMOFF ; show ALARM OFF message
btfsc ENGINEERSET,0 ; has ENGINEER been called?
goto MAIN ;yes
call LCD21 ;set address for line 1 cell 1
bsf RSLINE,4 ;set RS for data send
After conversion got:
#define page0 BCF $03,5
#define page1 BSF $03,5
LIST P = PIC16F877,R=DEC
__CONFIG h'3F31'
indf EQU H'00' ;Page 0, 1, 2, 3
option EQU H'01' ;Page 1, 3
pcl EQU H'02' ;Page 0, 1, 2, 3
status EQU H'03' ;Page 0, 1, 2, 3
fsr EQU H'04' ;Page 0, 1, 2, 3
porta EQU H'05' ;Page 0
trisa EQU H'05' ;Page 1
portb EQU H'06' ;Page 0, 2
trisb EQU H'06' ;Page 1, 3
portc EQU H'07' ;Page 0
trisc EQU H'07' ;Page 1
portd EQU H'08' ;Page 0
trisd EQU H'08' ;Page 1
porte EQU H'09' ;Page 0
trise EQU H'09' ;Page 1
pclath EQU H'0A' ;Page 0, 1, 2, 3
intcon EQU H'0B' ;Page 0, 1, 2, 3
eedata EQU H'0C' ;Page 2
eecon1 EQU H'0C' ;Page 3
pir2 EQU H'0D' ;Page 0
eeadr EQU H'0D' ;Page 2
eecon2 EQU H'0D' ;Page 3
adcon1 EQU H'1F' ;Page 1
slowit EQU H'20' ;Pause counter
clkcnt EQU H'21'
clksec EQU H'22'
clkmin EQU H'23'
clkhrs EQU H'24'
loop EQU H'25'
loopa EQU H'26'
rsline EQU H'27'
store EQU H'28'
store1 EQU H'29'
store2 EQU H'2A'
store3 EQU H'2B'
zonesval EQU H'2C' ;Current val of zones status
alarmstatus EQU H'2D' ;Controls the following:
;Bit 0 buzzer
;Bit 1 strobe
;Bit 2 bell
;Bit 3 -
;Bit 4 panic flag
;Bit 5 passive entry zone (just turns on buzzer when entered)
;Bit 6 power interrupt flag
;Bit 7 alarm on flag
switch1 EQU H'2E' ;Multiplex val for rows
swval EQU H'2F' ;Input val from rb0-rb3
col EQU H'30' ;Column counter (inc in decimal)
row EQU H'31' ;Row counter (inc as matrix val)
rownum EQU H'32' ;Row counter (inc in decimal)
alarmzone EQU H'33' ;Holds status of which zone triggered
keypress EQU H'34' ;Value of key pressed keypad1
pin0 EQU H'35' ;1st pin number val first keypad
pin1 EQU H'36' ;2nd pin number val
pin2 EQU H'37' ;3rd pin number val
pin3 EQU H'38' ;4th pin number val
exittime EQU H'39' ;Entry/exit delay
exitzone EQU H'3A' ;Entry/exit zone
inclzone EQU H'3B' ;Zones to be included in monitoring
belltime EQU H'3C' ;Bell on time value in bcd mins
flash EQU H'3D' ;Flag for flashing buzzer led when zone incorrectly open during alarm setting
zonenormal EQU H'3E' ;Normal zone logic
engineerset EQU H'3F' ;Flag to indicate if engineer has been called
prevalarmzone EQU H'40' ;Previous alarm condition register
entrydelay EQU H'41' ;Counter for entry/exit delay
pin4 EQU H'42' ;1st pin number val for 2nd keypad
pin5 EQU H'43' ;2nd pin number val
pin6 EQU H'44' ;3rd pin number val
pin7 EQU H'45' ;4th pin number val
keypress2 EQU H'46' ;Value of key pressed keypad2
entrytime2 EQU H'47' ;Entry time for keypad2
entrydelay2 EQU H'48' ;Counter for keypad2 entry delay
clkcnt2 EQU H'49'
stored EQU H'4A' ;Temp store for keypad2
count0 EQU 0x50 ;Lsb
count1 EQU 0x51
count2 EQU 0x52 ;Msb
digit1 EQU 0x53 ;Lsd
digit2 EQU 0x54
bitcnt EQU 0x5B
digcnt EQU 0x5C
storex EQU H'60'
storey EQU H'61'
;Locations up to $7f are available
;Bit definitions
w EQU 0
f EQU 1
c EQU 0
dc EQU 1
z EQU 2
rp0 EQU 5 ;Status reg
rp1 EQU 6 ;Status reg
gie EQU 7 ;Intcon reg
rd EQU 0 ;Eecon1 reg eeprom read enable flag
wr EQU 1 ;Eecon1 reg eeprom write initiate flag
wren EQU 2 ;Eecon1 reg eeprom write enable flag
eepgd EQU 7 ;Eecon1 reg
eeif EQU 4 ;Pir2 reg
buzzer EQU 0
strobe EQU 1
bell EQU 2
panic EQU 4
rbif EQU 0
;0-3 pin code
;4 zones excluded
;5 entry/exit zone
;6 entry/exit delay
;7 zones intruded (alarmzone)
;8 alarm on/off & bell, buzzer, strobe status (alarmstatus)
;9 bell on time (max 15 mins)
;10 normal zone status
;11-14 2nd pin code
;15 entry delay via keypad2
ORG H'0004' ;Interrupt vector address
GOTO gieoff ;Jump to interrupt routine on interrupt
ORG H'0005' ;Start of program memory
gieoff
BCF intcon,gie ;Turn off global interrupts
BTFSC intcon,gie
GOTO gieoff
GOTO start
tablcd
ADDWF pcl,f ;Lcd initialisation table
RETLW B'00110011' ;Initialise lcd - first byte
RETLW B'00110011' ;2nd byte (repeat of first)
RETLW B'00110010' ;Set for 4-bit operation
RETLW B'00101100' ;Set for 2 lines
RETLW B'00000110' ;Set entry mode to increment each address
RETLW B'00001100' ;Set display on, cursor off, blink off
RETLW B'00000001' ;Clear display
RETLW B'00000010' ;Return home, cursor & ram to zero
;End inititalisation table
alloff
ADDWF pcl,f
RETLW 'A'
RETLW 'L'
RETLW 'L'
RETLW ' '
RETLW 'O'
RETLW 'F'
RETLW 'F'
RETLW ' '
messagon
ADDWF pcl,f
RETLW 'A'
RETLW 'L'
RETLW 'A'
RETLW 'R'
RETLW 'M'
RETLW ' '
RETLW 'O'
RETLW 'N'
RETLW ' '
messag2
ADDWF pcl,f
RETLW ' '
RETLW ' '
RETLW 'E'
RETLW 'N'
RETLW 'T'
RETLW 'R'
RETLW 'Y'
RETLW ' '
chkval
ADDWF pcl,f
RETLW B'01011001' ;59 secs max
RETLW B'01011001' ;59 mins max
RETLW B'00100011' ;23 hours max
value
ADDWF pcl,f ;Lookup table for key allocation
RETLW '1'
RETLW '2'
RETLW '3'
RETLW 'A'
RETLW '4'
RETLW '5'
RETLW '6'
RETLW 'B'
RETLW '7'
RETLW '8'
RETLW '9'
RETLW 'C'
RETLW '-'
RETLW '0'
RETLW 'E'
RETLW 'D'
bitvalue
ADDWF pcl,f ;Lookup table for decimal to bit conversion
RETLW 0
RETLW 1
RETLW 2
RETLW 4
RETLW 8
RETLW D'16'
RETLW D'32'
RETLW D'64'
RETLW D'128'
pincode
ADDWF pcl,f ;Change pin code message
RETLW 'C'
RETLW 'H'
RETLW 'A'
RETLW 'N'
RETLW 'G'
RETLW 'E'
RETLW ' '
RETLW 'P'
RETLW 'I'
RETLW 'N'
RETLW ' '
RETLW 'C'
RETLW 'O'
RETLW 'D'
RETLW 'E'
RETLW ' '
pin2msg
ADDWF pcl,f ;Change 2nd pin code message
RETLW 'S'
RETLW 'E'
RETLW 'T'
RETLW ' '
RETLW '2'
RETLW 'N'
RETLW 'D'
RETLW ' '
RETLW 'P'
RETLW 'I'
RETLW 'N'
RETLW ' '
RETLW 'C'
RETLW 'O'
RETLW 'D'
RETLW 'E'
entrytime
ADDWF pcl,f ;Change entry/exit time message
RETLW 'S'
RETLW 'E'
RETLW 'T'
RETLW ' '
RETLW 'I'
RETLW 'N'
RETLW '/'
RETLW 'O'
RETLW 'U'
RETLW 'T'
RETLW ' '
RETLW 'T'
RETLW 'I'
RETLW 'M'
RETLW 'E'
RETLW ' '
belltimemsg
RETLW 'S'
RETLW 'E'
RETLW 'T'
RETLW ' '
RETLW 'B'
RETLW 'E'
RETLW 'L'
RETLW 'L'
RETLW ' '
RETLW 'O'
RETLW 'N'
RETLW ' '
RETLW 'T'
RETLW 'I'
RETLW 'M'
RETLW 'E'
entryzone
ADDWF pcl,f ;Set entry/exit zone message
RETLW 'S'
RETLW 'E'
RETLW 'T'
RETLW ' '
RETLW 'I'
RETLW 'N'
RETLW '/'
RETLW 'O'
RETLW 'U'
RETLW 'T'
RETLW ' '
RETLW 'Z'
RETLW 'O'
RETLW 'N'
RETLW 'E'
RETLW ' '
modemsg
ADDWF pcl,f ;Mode message
RETLW 'S'
RETLW 'E'
RETLW 'L'
RETLW 'E'
RETLW 'C'
RETLW 'T'
RETLW ' '
RETLW 'M'
RETLW 'O'
RETLW 'D'
RETLW 'E'
RETLW ' '
RETLW ' '
RETLW ' '
RETLW ' '
RETLW ' '
watchmsg
ADDWF pcl,f ;Zones to be watched message
RETLW 'S'
RETLW 'E'
RETLW 'T'
RETLW ' '
RETLW 'W'
RETLW 'A'
RETLW 'T'
RETLW 'C'
RETLW 'H'
RETLW ' '
RETLW 'Z'
RETLW 'O'
RETLW 'N'
RETLW 'E'
RETLW 'S'
RETLW ' '
openzone
ADDWF pcl,f ;Zones incorrectly open when alarm is being set
RETLW 'C'
RETLW 'H'
RETLW 'E'
RETLW 'C'
RETLW 'K'
RETLW ' '
RETLW 'O'
RETLW 'P'
RETLW 'E'
RETLW 'N'
RETLW ' '
RETLW 'Z'
RETLW 'O'
RETLW 'N'
RETLW 'E'
RETLW 'S'
zonelogic
ADDWF pcl,f ;Assess zone logic message (i.e normally open or normally closed)
RETLW 'A'
RETLW 'U'
RETLW 'T'
RETLW 'O'
RETLW ' '
RETLW 'Z'
RETLW 'O'
RETLW 'N'
RETLW 'E'
RETLW ' '
RETLW 'A'
RETLW 'S'
RETLW 'S'
RETLW 'E'
RETLW 'S'
RETLW 'S'
showlogic
RETLW 'N'
RETLW 'O'
RETLW 'R'
RETLW 'M'
RETLW ' '
RETLW 'Z'
RETLW 'O'
RETLW 'N'
RETLW 'E'
RETLW ' '
RETLW 'L'
RETLW 'O'
RETLW 'G'
RETLW 'I'
RETLW 'C'
RETLW ' '
passivemsg
ADDWF pcl,f ;Passive alarm message
RETLW 'M'
RETLW 'O'
RETLW 'N'
RETLW 'I'
RETLW 'T'
RETLW 'O'
RETLW 'R'
RETLW ' '
start
BCF status,rp0
BCF status,rp1
CLRF porta
CLRF portb
CLRF portc
CLRF portd
CLRF porte
PAGE1
MOVLW B'11011111' ;Rb0-rb4, rb6-rb7 as input, rb5 as output
MOVWF trisb
MOVLW B'00001111' ;Rc0-rc3 as input, rc4-rc7 as output
MOVWF trisc
MOVLW D'255'
MOVWF trisd ;Portd as input
CLRF trise ;Porte as output
MOVLW B'00000111' ;Port a/e as digital
MOVWF adcon1
MOVLW B'11000000' ;Ra0-ra5 as outputs
MOVWF trisa
MOVLW B'00000110' ;Timer 1:128 (1/25th sec)
MOVWF option
PAGE0
CLRF intcon
CALL pausit ;1/5 sec delay
lcdset
CLRF loop ;Clr lcd set-up loop
CLRF rsline ;Clear rs line for instruction send
lcdst2
MOVF loop,w ;Get table address
CALL tablcd ;Get set-up instruction
CALL lcdout ;Perform it
INCF loop,f ;Inc loop
BTFSS loop,3 ;Has last lcd set-up instruction now been done?
GOTO lcdst2 ;No
CLRF engineerset
BSF alarmstatus,6 ;Set power interruption flag
CALL keypad1 ;Is engineer code to be entered following power-up
MOVF keypress,w ;With key 'd' pressed?
XORLW 'D'
BTFSS status,z
GOTO setclk ;No
CLRF alarmzone
CLRF alarmstatus
BSF engineerset,0
BCF alarmstatus,6 ;Clear power interruption flag
MOVLW B'10000001' ;Default set inclzone for zones 1 & 8
MOVWF store1
MOVLW 4
CALL setprm
MOVLW B'00000001' ;Default set entry/exit zone
MOVWF store1
MOVLW 5
CALL setprm
MOVLW D'30' ;Default set exittime to 30 secs in binary
MOVWF store1
MOVLW 6
CALL setprm
CLRF store1 ;Default clear intruded status
MOVLW 7
CALL setprm
CLRF porte
CLRF store1 ;Default clear alarmstatus (bell etc)
BCF store1,bell
MOVLW 8
CALL setprm
MOVLW B'00010101' ;Default set bell switch-off time to 15 mins in bcd
MOVWF store1
MOVLW 9
CALL setprm
MOVLW B'00000000' ;Default set for "normal" zone status - all open
MOVWF store1
MOVLW D'10'
CALL setprm
MOVLW D'30' ;Default set entrytime to 30 secs in binary for keypad2
MOVWF store1
MOVLW D'15'
CALL setprm
CALL engineer ;Yes, set engineer entry code and reset all defaults
setclk
CLRF clksec ;Clear seconds counter
CLRF clkmin ;Clear minutes counter
CLRF clkhrs ;Clear hours counter
CLRF prevalarmzone
CLRF entrydelay
CLRF entrydelay2
MOVLW D'25' ;Initial basic clkcnt val for secs timing
MOVWF clkcnt
MOVLW 0 ;Recall pin code
CALL prmget
MOVWF pin0
MOVLW 1
CALL prmget
MOVWF pin1
MOVLW 2
CALL prmget
MOVWF pin2
MOVLW 3
CALL prmget
MOVWF pin3
MOVLW 4 ;Recall included/excluded zones
CALL prmget
MOVWF inclzone
BSF inclzone,7 ;Ensure bit 7 (1st panic zone) is always on
MOVLW 5 ;Recall entry/exit zone
CALL prmget
MOVWF exitzone
MOVLW 6 ;Recall entry/exit time
CALL prmget
MOVWF exittime
MOVLW 7 ;Recall alarmzone status
CALL prmget
MOVWF alarmzone
MOVLW 8 ;Recall alarmstatus status
CALL prmget
MOVWF alarmstatus ;And activate buzzer/strobe if needed (but not bell)
ANDLW B'00000011'
MOVWF porte
MOVLW 9 ;Recall bell on time
CALL prmget
MOVWF belltime
MOVLW D'10' ;Recall "normal zone status
CALL prmget
MOVWF zonenormal
MOVLW D'11' ;Recall pin code 2
CALL prmget
MOVWF pin4
MOVLW D'12'
CALL prmget
MOVWF pin5
MOVLW D'13'
CALL prmget
MOVWF pin6
MOVLW D'14'
CALL prmget
MOVWF pin7
MOVLW D'15' ;Recall entry time for keypad2
CALL prmget
MOVWF entrytime2
BTFSS alarmstatus,7 ;Is alarm on?
GOTO itsoff
CALL checkzone2
GOTO main
itsoff
CALL alarmoff ;Show alarm off message
BTFSC engineerset,0 ;Has engineer been called?
GOTO main ;Yes
CALL lcd21 ;Set address for line 1 cell 1
BSF rsline,4 ;Set rs for data send
Note, is a long code so chopped some off, just so you can see a sample conversion.
Format on converted MPASM is better than shown above. Code box appears to align text differently
