problems with the 18F25J50 USB
Posted: Sat Jan 22, 2011 12:49 pm
I have problems with the 18F25J50 USB.
My HI-TECH Compiler braeks with errors:
Build C:\Projekte_Flowcode\PIC_18F2xJ50\C_Formular\C_Formular for device 18F25J50
Using driver C:\Program Files (x86)\HI-TECH Software\PICC-18\PRO\9.65\bin\picc18.exe
Make: The target "C:\Projekte_Flowcode\PIC_18F2xJ50\C_Formular\USBTest.p1" is out of date.
Executing: "C:\Program Files (x86)\HI-TECH Software\PICC-18\PRO\9.65\bin\picc18.exe" --pass1 C:\Projekte_Flowcode\PIC_18F2xJ50\USBTest.c -q --chip=18F25J50 -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [103] C:\Projekte_Flowcode\PIC_18F2xJ50\USBTest.c; 221.57 #error: Target device does not have USB functionality
Error [141] C:\Projekte_Flowcode\PIC_18F2xJ50\USBTest.c; 249.28 die include Datei "USB/pic_utils.h" kann nicht geöffnet werden: No such file or directory
********** Build failed! *********
How I can eliminate this errors. Can You help me
My program is as follows:
//** File name: C:\Projekte_Flowcode\PIC_18F2xJ50\USBTest.c
//** Generated by: Flowcode v4.3.7.63
//** Date: Friday, January 21, 2011 21:58:26
//** Licence: Professional
//** Registered to:
//** http://www.matrixmultimedia.com
#define MX_PIC
//Definitionen für Microcontroller
#define P18F24J50
#define MX_SPI
#define MX_SPI_C
#define MX_SPI_SDI 4
#define MX_SPI_SDO 5
#define MX_SPI_SCK 3
#define MX_UART
#define MX_UART_C
#define MX_UART_TX 6
#define MX_UART_RX 7
#define MX_UART2
#define MX_UART2_A
#define MX_UART2_TX 0
#define MX_UART2_RX 1
#define MX_I2C
#define MX_MI2C
#define MX_I2C_C
#define MX_I2C_SDA 4
#define MX_I2C_SCL 3
#define MX_PWM
#define MX_PWM_CNT 2
#define MX_PWM_TRIS1 trisc
#define MX_PWM_1 2
#define MX_PWM_TRIS2 trisc
#define MX_PWM_2 1
#define MX_PWM_TRIS2a trisb
#define MX_PWM_2a 3
//Funktionen
#define MX_CLK_SPEED 48000000
#ifdef _BOOSTC
#include <system.h>
#endif
#ifdef HI_TECH_C
#include <pic18.h>
#endif
//Konfigurations-Daten
#ifdef _BOOSTC
#pragma DATA 0x300000, 0x8a
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#pragma DATA 0x300001, 0xf9
#endif
#ifdef _HI_TECH_C
__CONFIG(1, 0xf98a);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300002, 0x1d
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#pragma DATA 0x300003, 0xff
#endif
#ifdef _HI_TECH_C
__CONFIG(2, 0xff1d);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300004, 0x61
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#pragma DATA 0x300005, 0xf8
#endif
#ifdef _HI_TECH_C
__CONFIG(3, 0xf861);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300006, 0x81
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#pragma DATA 0x300007, 0xf1
#endif
#ifdef _HI_TECH_C
__CONFIG(4, 0xf181);
#endif
#ifdef _BOOSTC
#pragma DATA 0x300008, 0xff
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#pragma DATA 0x300009, 0xff
#endif
#ifdef _HI_TECH_C
__CONFIG(5, 0xffff);
#endif
#ifdef _BOOSTC
#pragma DATA 0x30000a, 0xff
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#pragma DATA 0x30000b, 0xff
#endif
#ifdef _HI_TECH_C
__CONFIG(6, 0xffff);
#endif
#ifdef _BOOSTC
#pragma DATA 0x30000c, 0xff
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#pragma DATA 0x30000d, 0xff
#endif
#ifdef _HI_TECH_C
__CONFIG(7, 0xffff);
#endif
//Interne Funktionen
#include "C:\Program Files (x86)\Matrix Multimedia\Flowcode V4\FCD\internals.h"
//Makro-Funktions-Deklarationen
void FCM_PIC_18F2xJ50_config_Header();
//Variablen-Deklarationen
char FCV_LF;
char FCV_M_RET;
char FCV_CR;
//Defines:
/**** Macro Substitutions ****
0x12BF = Vendor ID
0xF010 = Product ID
{40,3,'F',0,'l',0,'o',0,'w',0,'c',0,'o',0,'d',0,'e',0,' ',0,'U',0,'S',0,'B',0,' ',0,'S',0,'e',0,'r',0,'i',0,'a',0,'l',0}; = Device Name
{46,3,'M',0,'a',0,'t',0,'r',0,'i',0,'x',0,' ',0,'M',0,'u',0,'l',0,'t',0,'i',0,'m',0,'e',0,'d',0,'i',0,'a',0,' ',0,'L',0,'t',0,'d',0,'.',0}; = Device manufacturer
0 = Version Number A
1 = Version Number B
10 = Enumeration Wait Enable
0 = Enumeration Wait Time
40 = Length of Device Name String
46 = Length of Device Manufacturer String
// Component Defines
#define MX_VID 0x12BF //Eg 0x04D8
#define MX_PID 0xF010 //Eg 0x000C
#define MX_VERSION (1 <<
+ 0 //Eg 0x0200 = 2.0
#define MX_ENUMTIME 10 //Eg 1 - 255
#define MX_ENUMWAIT 0 //Eg 1 or 0
// Device name and manufacturer
char MX_USBNAME[40] = {40,3,'F',0,'l',0,'o',0,'w',0,'c',0,'o',0,'d',0,'e',0,' ',0,'U',0,'S',0,'B',0,' ',0,'S',0,'e',0,'r',0,'i',0,'a',0,'l',0};
char MX_USBMFR[46] = {46,3,'M',0,'a',0,'t',0,'r',0,'i',0,'x',0,' ',0,'M',0,'u',0,'l',0,'t',0,'i',0,'m',0,'e',0,'d',0,'i',0,'a',0,' ',0,'L',0,'t',0,'d',0,'.',0};
// Global Defines
#define CDC_TX_BUFFER_SIZE 64
#define CDC_RX_BUFFER_SIZE 64
#define CDC_DATA_ENDPOINT 3
#define USB_HIGHEST_EP 3
#define USB_BUS_POWERED
#ifdef MX_USB_TYPE1 //2455 Family
#define USB_DESCRIPTOR_BASE_ADDRESS 0x400
#define USB_EP0_OUT_ADDR 0x0500
#define USB_EP0_IN_ADDR 0x0508
#define USB_EP2_IN_ADDR 0x0510
#define USB_EP3_OUT_ADDR 0x0518
#define USB_EP3_IN_ADDR 0x0520
#endif
#ifdef MX_USB_TYPE2 //2450 Family
#define USB_EP0_OUT_ADDR 0x0480
#define USB_EP0_IN_ADDR 0x0488
#define USB_EP2_IN_ADDR 0x0490
#define USB_EP3_OUT_ADDR 0x0498
#define USB_EP3_IN_ADDR 0x04A0
#endif
#ifdef MX_USB_TYPE3 //14K50 Family
#define USB_DESCRIPTOR_BASE_ADDRESS 0x200
#define USB_EP0_OUT_ADDR 0x0280
#define USB_EP0_IN_ADDR 0x0288
#define USB_EP2_IN_ADDR 0x0290
#define USB_EP3_OUT_ADDR 0x0298
#define USB_EP3_IN_ADDR 0x02A0
#endif
#ifndef USB_DESCRIPTOR_BASE_ADDRESS
#ifdef _BOOSTC
#pragma error "Target device does not have USB functionality"
#endif
#ifdef HI_TECH_C
#error Target device does not have USB functionality
#endif
#endif
#define USB_EP0_OUT_SIZE 8
#define USB_EP0_IN_SIZE 8
#define USB_EP2_IN_SIZE 8
#define USB_EP3_OUT_SIZE 8
#define USB_EP3_IN_SIZE 8
#define USB_CALLBACK_ON_SOF
#define USB_CALLBACK_ON_DEVICE_CONFIGURED
#define USB_CALLBACK_ON_CTRL_CLASS
#define USB_EP_DATA_CALLBACK
//Serial Number
char MX_SERIAL[10] = {10,3,'0',0,'0',0,'0',0,'1',0};
// USB library includes
#ifdef _BOOSTC
#include <USB/pic_utils.h>
#include <USB/pic_usb_buffer_mgt.c>
#include <USB/pic_usb.c>
#include <USB/usb_cdc_class.c>
#include <USB/usb_config_serial.c>
#endif
#ifdef HI_TECH_C
#include "USB/pic_utils.h"
#include "USB/pic_usb_buffer_mgt.c"
#include "USB/pic_usb.c"
#include "USB/usb_cdc_class.c"
#include "USB/usb_config_serial.c"
#endif
// Variable to hold status of the USB connection
char CDC_USB_status = 0;
// Variable to hold incoming data
char CDC_USB_Rx_String[CDC_RX_BUFFER_SIZE];
void usb_device_configured_callback(void)
CDC_USB_status = 1;
//USBSerial(0): //Makro-Funktions-Deklarationen
void FCD_USBSerial0_configure_system();
char FCD_USBSerial0_Initialise_Serial();
char FCD_USBSerial0_SendByte(char byte);
char FCD_USBSerial0_SendString(char* String, char MSZ_String);
char FCD_USBSerial0_ReadByte(char timeout_ms);
void FCD_USBSerial0_ReadString(char* FCR_RETVAL, char FCR_RETVAL_SIZE, char timeout_ms, char length);
//USBSerial(0): //Makro-Implementierungen
kill_interrupts(); // turn off interrupts just in case
usb_cdc_setup();
usb_setup();
turn_peripheral_ints_on();
turn_global_ints_on();
uns16 delay_counter;
usb_configure_structures();
usb_enable_module();
delay_counter = 0;
#if MX_ENUMWAIT == 1
while(CDC_USB_status == 0 && delay_counter < 10000) //Wait for USB to startup and enumerate
delay_counter = delay_counter + 1;
delay_10us(MX_ENUMTIME); //Max wait
if (CDC_USB_status == 1)
return 0;
return 0xFF;
#else
while(CDC_USB_status == 0);
#endif
return 0;
unsigned int timeout = 0;
while (usb_cdc_tx_empty() == 0 && timeout < 32000) //Wait for outgoing buffer to empty
timeout = timeout + 1;
if (timeout == 32000) //Pipeline full or disconnected
return 1;
usb_cdc_putc(byte);
return 0;
return 1;
usb_cdc_print_str(String);
return 0;
static char position = 0;
static char length = 0;
char retval = 255;
char waitforever = 0;
if(timeout_ms == 255)
waitforever = 1;
if (position == length) // end of local string?
position = 0;
length = usb_cdc_rx_avail(); // get length of incoming data string
while (length == 0 && (timeout_ms || waitforever)) // wait for timeout_ms
Wdt_Delay_Ms(1);
timeout_ms = timeout_ms - 1; // decrement timeout_ms
if(length == 0)
return (retval); // return no data flag 255 / 0xFF
usb_ep_get_rx_buffer(length, CDC_USB_Rx_String); // copy data string to local buffer
retval = CDC_USB_Rx_String[position];
position = position + 1;
return (retval);
char i;
char Rx_Length;
if(length > FCR_RETVAL_SIZE)
length = FCR_RETVAL_SIZE;
waitforever = 1;
while (timeout_ms || waitforever)
Rx_Length = usb_cdc_rx_avail(); // get length of incoming data string
if (Rx_Length)
if (Rx_Length > length)
Rx_Length = length;
usb_ep_get_rx_buffer(Rx_Length, FCR_RETVAL); // copy data string to local buffer
if (Rx_Length < length)
FCR_RETVAL[Rx_Length] = 0; //Add null character to end of string
return;
else
Wdt_Delay_Ms(1);
//Konfiguriert den 18F2xJ50
//Configuration CPU System Clock extern und RTCC intern
//C-Kode:
__CONFIG(1,PLLDIV_3 & CPUDIV_OSC1 & XINST_OFF & WDTEN_OFF);
__CONFIG(2,OSC_HSPLL & T1DIG_OFF & FCMEN_OFF);
__CONFIG(3,RTCOSC_INTOSCREF & DSWDTEN_OFF);
//Enhanced PWM CCP1 Output Configuration bits
//C-Kode:
TRISB = TRISB & 0x11111011;// RB2
RPOR5 = 14; // ECCP1 PWM Output Channel A on PIN RP5
//Enhanced PWM CCP2 Output Configuration bits
//C-Kode:
TRISB = TRISB & 0x11110111; // RB3
RPOR6 = 18; // ECCP2 PWM Output Channel A on PIN RP6
//PWM 1 enable
//Aufruf Komponenten-Makro: PWM(0)::Enable(1)
FCD_PWM0_Enable(1);
//PWM enable 2
//Aufruf Komponenten-Makro: PWM(0)::Enable(2)
FCD_PWM0_Enable(2);
//Zeilenrücklauf für RS232
//Berechnung:
// LF = 10
// CR = 13
FCV_LF = 10;
FCV_CR = 13;
void main()
//Initialisierung
ancon0 = 0xFF;
ancon1 = 0x1F;
//Interrupt-Initialisierungs-Kode
//Makro-Aufruf: PIC_18F2xJ50_config_Header
//Schleife: While m_ret = 255
while (1)
//Aufruf Komponenten-Makro: m_ret=USBSerial(0)::Initialise_Serial
FCV_M_RET = FCD_USBSerial0_Initialise_Serial();
if ((FCV_M_RET == 255) == 0) break;
//Schleife: While 1
while (1)
//Aufruf Komponenten-Makro: m_ret=USBSerial(0)::SendString("Test, ")
FCV_M_RET = FCD_USBSerial0_SendString("Test, ",6);
//Output: 1 -> C2
trisc = trisc & 0xfb;
if (1)
portc = (portc & 0xfb) | 0x04;
else
portc = portc & 0xfb;
//Warten: 500 ms
Wdt_Delay_Ms(255);
Wdt_Delay_Ms(245);
//Output: 0 -> C2
if (0)
else
//Warten: 500 ms
Wdt_Delay_Ms(255);
Wdt_Delay_Ms(245);
mainendloop: goto mainendloop;
void MX_INTERRUPT_MACRO(void)
usb_handle_isr();
//** Registered to:
#define MX_PIC
#define P18F24J50
#define MX_SPI
#define MX_SPI_C
#define MX_UART
#define MX_UART_C
#define MX_UART2
#define MX_UART2_A
#define MX_I2C
#define MX_MI2C
#define MX_I2C_C
#define MX_PWM
#define MX_PWM_1 2
#define MX_PWM_2 1
#define MX_PWM_2a 3
//Funktionen
#ifdef _BOOSTC
#include <system.h>
#endif
#ifdef HI_TECH_C
#include <pic18.h>
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
//__CONFIG(, );
#endif
#ifdef _BOOSTC
#endif
#ifdef _HI_TECH_C
#endif
char FCV_LF;
char FCV_M_RET;
char FCV_CR;
//Defines:
0x12BF = Vendor ID
0xF010 = Product ID
// Global Defines
#endif
#endif
#endif
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
#endif
//Serial Number
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
CDC_USB_status = 1;
usb_cdc_setup();
usb_setup();
delay_counter = 0;
return 0;
return 0xFF;
#else
#endif
return 0;
return 1;
usb_cdc_putc(byte);
return 0;
return 1;
return 0;
char retval = 255;
waitforever = 1;
position = 0;
Wdt_Delay_Ms(1);
if(length == 0)
return (retval);
char i;
char Rx_Length;
waitforever = 1;
if (Rx_Length)
Rx_Length = length;
return;
else
Wdt_Delay_Ms(1);
//C-Kode:
//C-Kode:
//C-Kode:
//PWM 1 enable
FCD_PWM0_Enable(1);
//PWM enable 2
FCD_PWM0_Enable(2);
//Berechnung:
// LF = 10
// CR = 13
FCV_LF = 10;
FCV_CR = 13;
void main()
//Initialisierung
ancon0 = 0xFF;
ancon1 = 0x1F;
while (1)
//Schleife: While 1
while (1)
//Output: 1 -> C2
if (1)
else
//Warten: 500 ms
Wdt_Delay_Ms(255);
Wdt_Delay_Ms(245);
//Output: 0 -> C2
if (0)
else
//Warten: 500 ms
Wdt_Delay_Ms(255);
Wdt_Delay_Ms(245);
usb_handle_isr();
